i cannot get this to work.
I have tried both the dongle serial number and the mqqt username within HA.
Can you give me some guidance
Hi I try to add this repo but not success.
can you help?
Sorry
What is it?
What is AlexIt ?
I am not Alex
sorry, itâs NOT repository for HASS.
just download files as zip
unpack to folder
so I have downloaded the zip file and uploaded it to custom comonenet.
what do I do now?
sorry i canât replicate, could you post an example ? inserting username and password of mqtt as for your example wonât work
Iâm not an expert at all, but I like to try out things. Using the hints and add-on from Oleg Denisenko, I now have my Epever Tracer AN 2210 with wifi dongle integrated in HA. I run HA in a virtual machine on a Synology server, using the latest software versions. Within HA I installed add-ons for File editor, Mosquito broker, MQTT Explorer and Samba share. As advised by many documents, I created a Synology user for MQTT with password.
These are the steps I took:
Wifi dongle installation
I followed the guidelines from the manufacturer to start with. Using a network scanner I found out the DHCP assigned IP address, and then logged in on the web interface of the dongle (using the combination admin / admin).
Side note: I first wanted to set the dongle on STA mode only, but that didnât work out for some reason. After a while I realized itâs not too bad at all to have both modes enabled. I now use the AP mode with the Solar Giuardian app in Local Mode to occasionally change settings (like when the battery is replaced).
My settings are (with 192.168.1.147 being the local IP address):
AP Setting - no changes
STA Setting - to me itâs very important to have a fixed IP address assigned to the dongle, eventually also in the DHCP server.
Next, following Olegâs discovery:
The Epever solar client add-on
- Copied the complete folder from GitHub - 10der/hass-epever-solar-client to the HA addons folder (using Samba).
- Corrected a typo in the file epever-solar-client.py
Line 16 âfrom pymodbus.mei_message import ReadDeviceInformationRequestâ should be: âfrom pymodbus.pdu.mei_message import ReadDeviceInformationRequestâ - I reloaded the HA configuration files, and the add-on appears next to the other add-ons.
- In the configuration tab, following Olegâs directions:
(see next post, as I can only upload one media item - this is my first post).
HA set-up
Using the MQTT explorer, I could easily see all data that the dongle server sends out. You may have to wait a while, but itâs all there, just like Oleg showed above.
For my purposes I added this mqtt:-section in the configuration.yaml.
mqtt:
- name: "input voltage"
unique_id: input_voltage
state_topic: "home/epever-solar/epever/data"
value_template: '{{ value_json["chargingInputVoltage"] }}'
unit_of_measurement: "V"
device:
identifiers: Tracer2210AN
manufacturer: "Epever"
model: "V01.02"
- name: "input current"
unique_id: station_input_current
value_template: '{{ value_json["chargingInputCurrent"] }}'
unit_of_measurement: "A"
device:
model: "V01.02"
- name: "input power"
unique_id: station_input_power
value_template: '{{ value_json["chargingInputPower"] }}'
#last_reset_value_template: "{{value_json.lastUpdate | int | timestamp_custom('%d.%m.%Y %H:%M'}}"
unit_of_measurement: "W"
device:
model: "V01.02"
- name: "battery charging voltage"
unique_id: station_battery_charging_voltage
value_template: '{{value_json["chargingOutputVoltage"] }}'
device_class: voltage
device:
model: "V01.02"
- name: "battery charging current"
unique_id: station_battery_charging_current
value_template: '{{value_json["chargingOutputCurrent"] }}'
device_class: current
device:
model: "V01.02"
- name: "battery charge level"
unique_id: station_battery_charge_level
value_template: '{{value_json["batterySoC"] }}'
unit_of_measurement: "%"
device_class: battery
device:
model: "V01.02"
- name: "charging status"
state_topic: "home/epever-solar/epever/status"
unique_id: station_charging_status
value_template: '{{value_json["equipmentStatus"]["battery"] }}'
device:
model: "V01.02"
Itâs straightforward to add more parameters if you like, but for me this is sufficient.
Next post shows how it looks like (Iâm limited in media uploads, as before)
I hope this helps others too!
First of all: Thank you SO MUCH ReRuRabs for helping us out with this. Youâre a star.
I get an unspecified syntax error after replacing the typo. Can you confirm that this is what it should look like?
import paho.mqtt.client as mqtt
from pymodbus.client import ModbusTcpClient
from pymodbus.transaction import ModbusRtuFramer as ModbusFramer
from pymodbus.*pdu.*mei_message import ReadDeviceInformationRequest
root = logging.getLogger()
root.setLevel(logging.INFO)
Hi, I just noticed additional symbols in my edit, that shouldnât be there.
This is correct (and I updated my text too):
Brilliant! Itâs working. Iâve been looking for a solution for this for years and you came to the rescue an hour after I got the RJ45 D in the mail. Thank you!
Hello, I have this error trying to start the local addon:
Starting EPEVER solar clientâŚ
File â//./epever-solar-client.pyâ, line 15, in
ImportError: cannot import name âModbusRtuFramerâ from âpymodbus.transactionâ (/usr/local/lib/python3.12/site-packages/pymodbus/transaction.py)
Can you help.
