Epever wifi 2.4g rj45 d
I bought the epever wifi 2.4g rj45 d https://www.epever.com/product/epever-wifi-adapter-2-4g-rj45-d/ lately. After a little experimentation I have the device in my wifi network.
Since the cloud solution is bad from my point of view, I thought I’d try an alternative, since the EPever solutions in the past were poorly secured.
So I called the IP in the browser and logged in with the hard to guessed user : admin with the password : admin.
It turns out that you can configure mqtt via the webinterface. Unfortunately, my attempts so far have been unsuccessful.
Can anyone help me or at least give me a suggestion?
Thanks in advance!
A username and password for your MQTT server would be a start?
I have used the HA user and password, but since it is in plain text… I do not want to publish it
It’s not the HA user/pass - it’s the MQTT server credentials …
I use the HA MQTT addon without credentials. see
Other mqtt integrations are working flawless.
Do you have any Solution for this Problem?
Any luck with this? I wanted to buy USB cable or WiFi dongle, now can’t decide.
