thanks - now everything works fine
is there a possibility that some one (looking at @gigatexel) ^^ modify the script above with the 3 lowest hours for the next 48 hours. Plus date and price in the output?
I tried it by myself but i wasnât able to do that.
Iâm also confused by the output of the sensor.epex_spot_at_price because iâm getting wrong prices. i have to shift it 2 hours then the price is correct
@Presl1983 The time is shown as UTC timestamp - which is the standard time format for computing systems. You can see it also, because the timestamps ends with +00:00
. Home Assistant also knows about that and adjusts the timestamp according to your configured time zone.
Like in SQL so i have to work with it Or is there a setting to maintain that.
I think i will try to rework the Script with some other loops. Because i only need the now() time stamp +34 hours and so on.
Hello - absolut new here.
i use the code to finde the best time to heat the water - works great in the dashboard
but how to use the time in automation?
i use the helper as automation trigger - but cant find it as âtime triggerâ
if i change the helper to âtime-stampâ i get no result âŠ
any idea? i tried the whole weekâŠ
Is there a plan to offer V 2.1 via HACS? With HA 2023.10.3 latest version offered in HACS is 2.0.
Iâm struggling a bit to find the sensor.epex_spot_at_price - the only sensors what I have are:
Where can I find the Austria aWATTar pricesâŠ
Iâm a newbie so apologize my may dump question
Edit:
I guess there was sensor name change - sensor.expex_spot_data_net_price delivers the correct price depending on what is configured, in my case aWATTar âŠ
Hello , how to get the tomorrow values , thanks for your support
They come online approx at 2 pm.
yes, thanks a lot, the template sensor works
I tried to install the integration but when adding it via HA it just shows âUnknown error occurredâ (see screenshot) - regardless which option of data source.
âha core logsâ show me :
AttributeError: module âcustom_components.epex_spot.EPEXSpot.EPEXSpotWebâ has no attribute âEPEXSpotWebâ
I have this versions installed :
- Core2023.11.3
- Supervisor2023.11.3
- Operating System8.5
- Frontend20231030.2
Can you give me a hint how to overcome this error ?
BR
Michael
Probably there are files missing. How did you install the integration? Via HACS?
If yes, please try to reinstall.
you were right, there were files missing ⊠even if a copied all via rsync to my HA filesystem for a manual installation.
After putting missing files under âcustom_components/epex_spotâ and doing a âha core restartâ integration was added and configured successfully
Thx for you hint
BR
Michael
Hallo. Ich bin neu hier. Können Sie mir bitte erklĂ€ren wie ich genau vorgehen muss. Ich habe epex installiert. aber wo genau muss ich diese Tabellen jetzt einfĂŒgen um so eine Karte zu bekommen?
LG
Sorry, I donât understand your problem (not because of the language!). What do you mean with table?
Du musst dir mal viele Youtube Videos anschauen und die basics lernen.
