Hi everyone, I’m quite a beginner with HA I’m just learning. I’m trying to load FW via ESP Home to 8266-01 according to the instructions, see the link below. The compilation is fine, but writing to the board reports an error, I googled something about reducing the communication speed, but I don’t know how. Can someone please advise me? I used this page as a guide: http://www.emcu.eu/esphome-for-drive-eps...assistant/. After trying to write to the record, it writes this, at the very bottom:
INFO Reading configuration /config/esphome/cccc1.yaml…
INFO Generating C++ source…
INFO Compiling app…
INFO Running: platformio run -d /config/esphome/cccc1
Processing cccc1 (board: esp01_1m; framework: arduino; platform: [email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
PACKAGES:
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Dependency Graph
|-- 1.2.3
| |-- 1.0
|-- 1.0
|-- 1.2
| |-- 1.0
|-- 1.2.7
| |-- 1.2.3
| | |-- 1.0
| |-- 1.0
| |-- 1.0
|-- 1.1.1
| |-- 1.0
Retrieving maximum program size /data/cccc1/.pioenvs/cccc1/firmware.elf
Checking size /data/cccc1/.pioenvs/cccc1/firmware.elf
RAM: [==== ] 44.4% (used 36368 bytes from 81920 bytes)
Flash: [==== ] 38.0% (used 388748 bytes from 1023984 bytes)
========================= [SUCCESS] Took 7.36 seconds =========================
INFO Successfully compiled program.
INFO Running: esptool.py --before default_reset --after hard_reset --baud 460800 --chip esp8266 --port /dev/ttyUSB0 write_flash 0x0 /data/cccc1/.pioenvs/cccc1/firmware.bin
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting…………………_____
A fatal error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
INFO Running: esptool.py --before default_reset --after hard_reset --baud 115200 --chip esp8266 --port /dev/ttyUSB0 write_flash 0x0 /data/cccc1/.pioenvs/cccc1/firmware.bin
esptool.py v2.8
