My esphome device with HA sourced time seems to not have control over which timezone is used. If I leave timezone: out of the config, it usually just displays UTC. Adding timezone into the config as shown results in the correct time for a short time after reboot, then it reverts to showing UTC after a while:
substitutions:
friendly_name: "Test Wemos"
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${friendly_name} Fallback Hotspot"
password: "password"
captive_portal:
logger:
api:
password: !secret test_wemos_password
# Enable ota
ota:
password: !secret ota_password
# Device Specific Configs ###########################################
# Test Wemos D1 Mini board
# Built In LED = GPIO2
# GPIO13 = D7
# SSD1306 Configs
time:
- platform: homeassistant
timezone: "America/Los_Angeles"
mqtt:
broker: 192...
username: !secret mqtt_client_user1
password: !secret mqtt_client_pass1
font:
- file: "verdana.ttf"
i2c:
sda: D1
scl: D2
display:
- platform: ssd1306_i2c
pages:
- id: page1
lambda: |-
it.strftime(0, 0, id(my_fontlg), "%I:%M:%S %p", id(ha_time).now());
it.strftime(0, 20, id(my_fontlg), "%a, %b %d", id(ha_time).now());
it.printf(0, 55, id(my_fontlg), "BckYd: %.1f F", id(backyard_temp).state);
if (id(button).state) {
it.line(0, 63, 127, 63);
- id: page2
lambda: |-
it.strftime(0, 5, id(my_fontlg), "%I:%M:%S %p", id(ha_time).now());
it.strftime(0, 25, id(my_fontlg), "%m-%d-%Y", id(ha_time).now());
model: "SSD1306 128x64"
reset_pin: D0
address: 0x3C
interval:
- interval: 5s
then:
- display.page.show_next: my_display
- component.update: my_display
# DFplayer configs
uart:
tx_pin: D5
rx_pin: D6
baud_rate: 9600
# Declare DFPlayer mini module
dfplayer:
on_finished_playback:
then:
logger.log: 'Somebody press play!'
# Generic configs
binary_sensor:
- platform: status
- platform: gpio
pin:
number: GPIO13
mode: INPUT_PULLUP
inverted: true
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
then:
- switch.turn_on: led
- dfplayer.set_volume: 25
- delay: 150ms
- dfplayer.play_next:
on_release:
then:
- switch.turn_off: led
#status_led:
# pin: GPIO2
- platform: wifi_signal
name: "${friendly_name} WiFi Signal"
update_interval: 60s
- platform: mqtt_subscribe
name: "Backyard Temperature"
topic: esphome/backyard_temp
switch:
- platform: gpio
pin: GPIO2
inverted: true
Not sure if I’m just trippin’, but I swear this problem didn’t happen until after I added in the dfplayer stuff. Everything else in this test code is working as expected. I’m guessing there just some simple error in my config. Any help getting timezones working reliably here is greatly appreciated.
