You’re probably right although I paid I think $80 for the flex. If you know of any alternatives that are more HA friendly I’d take a look !?
Have you seen this?
https://blog.flowblok.id.au/2012-11/controlling-projectors-with-pjlink.html
Looks to support projectors with pjlink over the network.
Take a look at this as well…
if some could add this as a default to home assistant we could all use this with our network projectors.
Thanks! The pypjlink worked like a charm on optoma!
Did you get it to work with home assistant? or just outside of home assistant?
I now have a switch in HA that updates with correct status. I have the UHD550X.
Mind posting your config so we can see how you implemented pypjlink?
Sure. Not home now, but I can try tomorrow
I installed the pypjlink as described and just use this config:
switch:
- platform: command_line
switches:
projector_status_command_line:
command_on: '/srv/homeassistant/bin/pjlink -p PROJECTOR_IP power on'
command_off: '/srv/homeassistant/bin/pjlink -p PROJECTOR_IP power off'
command_state: '/srv/homeassistant/bin/pjlink -p PROJECTOR_IP power'
value_template: '{{ value == "on" }}'
friendly_name: Prosjektor
I’m trying to do the same with my UHD51A, could you please explain how to install the pjlink script into HA? Thanks.
I just followed this page to install: https://blog.flowblok.id.au/2012-11/controlling-projectors-with-pjlink.html
I don’t use this anymore because they made the pjlink media player platform work. If none of them work for you, maybe you can’t connect to you projector? Have you tried tried the commands? Do you have web access? ping reply?
Thanks for answering. My Home Assistant is in a VM environment (Hyper-V), so I’m not sure I can use pip install
to get Pjlink installed. I’ve tried the official Pjlink platform but somehow the projector (UHD51A) is not found. Other Pjlink software apps are able to find it and control it, so I’m a little lost here. I also get access to the web control page. If you have any ideas or suggestions, please let me know. Here’s the log when I try the Pjlink component. Thanks again!
Error while setting up platform pjlink
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 442, in wait_for
return fut.result()
File "/usr/src/homeassistant/homeassistant/components/pjlink/media_player.py", line 61, in setup_platform
device = PjLinkDevice(host, port, name, encoding, password)
File "/usr/src/homeassistant/homeassistant/components/pjlink/media_player.py", line 84, in __init__
with self.projector() as projector:
File "/usr/src/homeassistant/homeassistant/components/pjlink/media_player.py", line 96, in projector
projector.authenticate(self._password)
File "/usr/local/lib/python3.7/site-packages/pypjlink/projector.py", line 83, in authenticate
assert data[:7] == 'PJLINK '
AssertionError
what is your config?
Pretty simple:
media_player:
- platform: pjlink
host: 10.10.12.41
port: 4352
Update: Other Pjlink software, scripts and apps do work with the projector
If you dont have pjlink, you can easily send rs232 commands with an esp8266 https://blog.lewys.eu/?p=765
If the IP and port is correct I have no idea, sorry. If other scripts work, couldn’t you just use those with the command_line switch I pasted above?
Wish I could, but my Home Assistant is in VM so I cannot install pypjlink. I guess my only option is going back in time and use telnet commands…
Here’s what I ended up doing, in case someone ends up in the same situation as me (Pjlink official component not recognizing my Optoma UHD51A). With this command line switch you can use the same Pjlink protocol:
scan_interval: 10
switches:
optoma:
friendly_name: "Optoma UHD51A 4K"
command_on: echo -e "%1POWR 1\r" | nc 10.10.12.41 4352
command_off: echo -e "%1POWR 0\r" | nc 10.10.12.41 4352
command_state: echo -e "%1POWR ?\r" | nc 10.10.12.41 4352 | tr '\r' '\n'
value_template: '{{ value == "pjlink 0\n%1powr=1" }}'
My projector returns power state in the form of
pjlink 0
%1powr=1
so I had to add \n
in the middle to make value_template
work.
Now the only issue has to do with how command_state
works: when I switch the projector on, the state of the switch goes ON for one second, then OFF for like 20 seconds and finally ON. That’s because my projector takes 20 seconds to go from %1powr 0
to %1powr 1
when turned ON, and viceversa when turned OFF. It’s mostly a visual inconvenience, but I wonder if someone can think of a way to delay command_state
check for 20 seconds after the switch has been turned on or off.
Nice👌
I had a 20 sec startup too, but was never a problem so didn’t try to fix.
Just out of curiosity, with the official Pjlink component, do you have the same 20-sec delay?
Hi all, sorry for bumping this up. I’m a newbie to HA and I’m trying to change the lens zoom settings in my Epson 6050UB. I can connect to it via pjlink media player integration, but I have not been able to figure out how to send it commands outside of the media_player command list. I have the command I want from the Epson ESC/VP21 but just don’t know the format for pjlink. Can someone share a script or automation file showing how to actually send commands through the pjlink media player integration?
