eQ-3 MAX! automation
Hello there,
so I’ve successfully installed Max! Cube into HA, and I have also 2 thermostat connected.
So I can switch them on or off (setting the lowest or the highest temperature), I was wondering: how to create an automation that let me set temperature? I haven’t find any command to do it, is it possible?
Thanks in advance
hi
I am currently working on the same topic, and what I understood is that you need to use the service related to the climate domain, such as climate.set_operation_mode or climate.set_temperature but not all of them are available with the Cube
see this link for details about the climate domain
There are a lot of bugs with eq3-MAX! cube and their software. I started using http://www.dmitry-kazakov.de/ada/max_home_automation.htm
It has Mqtt server and http control but I’m yet to discover how to set it up to work with HA
yes I’m aware of this tool, and the component is currently lacking some possibilities (such as setting the eco or comfort mode)
I’m only starting to set up my HASS installation, and I’d have to take some time to work on a headless installation on a RPi plus get to understand MQTT which I’m not using at the moment, but it would be interesting to use this software to interact with the Cube!
