Eria Dimming Switch Setup
I recently purchased 2 Eria Dimming Switches and got them synced up via my Zigbee hub.
The device can be found here:
Unfortunately I am not able to use them as it looks like Home Assistant doesn’t know what to do with them, do I need to setup a device handler or something similar in order to get these working?
If anybody can point me in the right direction I would greatly appreciate it.
Thank you!
Still looking for help with this if anybody has purchased these before.
I have them added into the ZHA configuration area in Home Assistant but despite that I don’t see an entity for them.
Same here, I bought One Eria Adurosmart dimmable smart plug.
The setup went well and Home Asistant said I could use the device. Unfortunatly when I wanted to use the plug, nothing happened.
My setup is a RaspberryPi3 with Conbee II stick, where the device is known by “BDP3001
door AduroSmart Eria”.
Just for future users - I would stear clear of this one if using ZHA. I’ve been able to add the plug with the Zigbee integration, but only a few entities show up. I can turn on and off the light and can set the light level when powering off, but no entity for direct dimming. Even if you’d like to use it with the Adurosmart app, you’d need a hub.
It’s supposed to work well with z2mqqt, but I’m not willing to haul over all my zigbee devices there.
