Hi Folks,
I was running HomeAssistant and hadn’t updated in a while. I used the following commands to update:
sudo su -s /bin/bash hass
source /srv/hass/hass_venv/bin/activate
pip3 install --upgrade homeassistant
After that, I can see that home assistant is not running in services
pi@raspberrypi:~ $ ps -aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 1.6 0.4 22824 3992 ? Ss 16:07 0:03 /sbin/init
root 2 0.0 0.0 0 0 ? S 16:07 0:00 [kthreadd]
root 3 0.0 0.0 0 0 ? S 16:07 0:00 [ksoftirqd/0]
root 4 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/0:0]
root 5 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/0:0H]
root 6 0.1 0.0 0 0 ? R 16:07 0:00 [kworker/u8:0]
root 7 0.0 0.0 0 0 ? S 16:07 0:00 [rcu_sched]
root 8 0.0 0.0 0 0 ? S 16:07 0:00 [rcu_bh]
root 9 0.0 0.0 0 0 ? S 16:07 0:00 [migration/0]
root 10 0.0 0.0 0 0 ? S 16:07 0:00 [migration/1]
root 11 0.0 0.0 0 0 ? S 16:07 0:00 [ksoftirqd/1]
root 12 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/1:0]
root 13 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/1:0H]
root 14 0.0 0.0 0 0 ? S 16:07 0:00 [migration/2]
root 15 0.0 0.0 0 0 ? S 16:07 0:00 [ksoftirqd/2]
root 16 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/2:0]
root 17 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/2:0H]
root 18 0.0 0.0 0 0 ? S 16:07 0:00 [migration/3]
root 19 0.0 0.0 0 0 ? S 16:07 0:00 [ksoftirqd/3]
root 20 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/3:0]
root 21 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/3:0H]
root 22 0.0 0.0 0 0 ? S 16:07 0:00 [kdevtmpfs]
root 23 0.0 0.0 0 0 ? S< 16:07 0:00 [netns]
root 24 0.0 0.0 0 0 ? S< 16:07 0:00 [perf]
root 25 0.0 0.0 0 0 ? S 16:07 0:00 [khungtaskd]
root 26 0.0 0.0 0 0 ? S< 16:07 0:00 [writeback]
root 27 0.0 0.0 0 0 ? S< 16:07 0:00 [crypto]
root 28 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 29 0.0 0.0 0 0 ? S< 16:07 0:00 [kblockd]
root 30 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/0:1]
root 31 0.0 0.0 0 0 ? S< 16:07 0:00 [rpciod]
root 32 0.0 0.0 0 0 ? S 16:07 0:00 [kswapd0]
root 33 0.0 0.0 0 0 ? S< 16:07 0:00 [vmstat]
root 34 0.0 0.0 0 0 ? S 16:07 0:00 [fsnotify_mark]
root 35 0.0 0.0 0 0 ? S< 16:07 0:00 [nfsiod]
root 44 0.0 0.0 0 0 ? S< 16:07 0:00 [kthrotld]
root 45 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/1:1]
root 46 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/2:1]
root 47 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 48 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 49 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 50 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 51 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 52 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 53 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 54 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 55 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 56 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 57 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 58 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 59 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 60 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 61 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 62 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 63 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 64 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 65 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 66 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 67 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 68 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 69 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 70 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 71 0.0 0.0 0 0 ? S< 16:07 0:00 [VCHIQ-0]
root 72 0.0 0.0 0 0 ? S< 16:07 0:00 [VCHIQr-0]
root 73 0.0 0.0 0 0 ? S< 16:07 0:00 [VCHIQs-0]
root 74 0.0 0.0 0 0 ? S< 16:07 0:00 [iscsi_eh]
root 75 0.0 0.0 0 0 ? S< 16:07 0:00 [dwc_otg]
root 76 0.0 0.0 0 0 ? S< 16:07 0:00 [DWC Notificati
root 77 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/u8:1]
root 78 0.0 0.0 0 0 ? S 16:07 0:00 [irq/92-mmc1]
root 79 0.0 0.0 0 0 ? S 16:07 0:00 [VCHIQka-0]
root 80 0.0 0.0 0 0 ? S< 16:07 0:00 [SMIO]
root 81 0.0 0.0 0 0 ? S< 16:07 0:00 [bioset]
root 82 0.2 0.0 0 0 ? S 16:07 0:00 [mmcqd/0]
root 83 0.0 0.0 0 0 ? S< 16:07 0:00 [deferwq]
root 84 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/u8:2]
root 85 0.0 0.0 0 0 ? S 16:07 0:00 [jbd2/mmcblk0p2
root 86 0.0 0.0 0 0 ? S< 16:07 0:00 [ext4-rsv-conve
root 87 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/3:1]
root 88 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/2:2]
root 89 0.0 0.0 0 0 ? S< 16:07 0:00 [ipv6_addrconf]
root 108 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/0:2]
root 114 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/u8:3]
root 121 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/2:3]
root 125 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/1:2]
root 136 0.2 0.3 9944 2860 ? Ss 16:07 0:00 /lib/systemd/sy
root 139 0.1 0.3 11916 3172 ? Ss 16:07 0:00 /lib/systemd/sy
root 236 0.0 0.0 0 0 ? S< 16:07 0:00 [cfg80211]
root 241 0.0 0.0 0 0 ? S< 16:07 0:00 [brcmf_wq/mmc1:
root 243 0.0 0.0 0 0 ? S 16:07 0:00 [brcmf_wdog/mmc
root 244 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/0:3]
root 268 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/3:2]
root 415 0.0 0.2 5072 2384 ? Ss 16:07 0:00 /usr/sbin/cron
root 418 0.0 0.2 3852 2396 ? Ss 16:07 0:00 /lib/systemd/sy
avahi 424 0.0 0.2 3876 2576 ? Ss 16:07 0:00 avahi-daemon: r
message+ 426 0.0 0.3 5708 3200 ? Ss 16:07 0:00 /usr/bin/dbus-d
root 430 0.0 0.1 2564 1776 ? Ss 16:07 0:00 /sbin/dhcpcd -q
nobody 442 0.0 0.1 2292 1448 ? Ss 16:07 0:00 /usr/sbin/thd -
avahi 448 0.0 0.0 3876 240 ? S 16:07 0:00 avahi-daemon: c
root 481 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/1:1H]
root 493 0.0 0.2 32144 2740 ? Ssl 16:07 0:00 /usr/sbin/rsysl
root 507 0.0 0.3 7156 3376 ? Ss 16:07 0:00 /sbin/wpa_suppl
root 541 0.0 0.4 7864 4408 ? Ss 16:07 0:00 /usr/sbin/sshd
root 550 0.0 0.7 40544 6824 ? Ssl 16:07 0:00 /usr/sbin/light
mosquit+ 574 0.0 0.3 5420 3516 ? Ss 16:07 0:00 /usr/local/sbin
root 584 0.0 0.2 5668 2760 tty1 Ss 16:07 0:00 /bin/login -f
ntp 622 0.0 0.3 5688 3632 ? Ss 16:07 0:00 /usr/sbin/ntpd
root 634 0.1 2.7 101604 26028 tty7 Ssl+ 16:07 0:00 /usr/bin/X :0 -
root 646 0.0 0.7 32876 7240 ? Sl 16:07 0:00 lightdm --sessi
pi 654 0.0 0.3 4976 3384 ? Ss 16:07 0:00 /lib/systemd/sy
pi 657 0.0 0.1 6804 1156 ? S 16:07 0:00 (sd-pam)
pi 660 0.0 1.2 52244 12248 ? Ssl 16:07 0:00 /usr/bin/lxsess
root 676 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/u9:0]
root 677 0.0 0.0 0 0 ? S< 16:07 0:00 [hci0]
root 678 0.0 0.0 0 0 ? S< 16:07 0:00 [hci0]
root 679 0.0 0.0 2068 148 ? S 16:07 0:00 /usr/bin/hciatt
root 681 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/u9:1]
root 682 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/u9:2]
root 686 0.0 0.3 5008 3336 ? Ss 16:07 0:00 /usr/lib/blueto
root 708 0.0 0.0 0 0 ? S 16:07 0:00 [kworker/0:4]
pi 717 0.0 0.0 3700 220 ? Ss 16:07 0:00 /usr/bin/ssh-ag
pi 721 0.0 0.1 3692 1636 ? S 16:07 0:00 /usr/bin/dbus-l
pi 722 0.0 0.2 5624 2264 ? Ss 16:07 0:00 /usr/bin/dbus-d
pi 731 0.1 0.4 6572 4496 tty1 S+ 16:07 0:00 -bash
pi 739 0.0 0.6 30852 5724 ? Sl 16:07 0:00 /usr/lib/gvfs/g
root 744 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/2:1H]
pi 830 0.0 0.5 48520 5316 ? Sl 16:07 0:00 /usr/lib/gvfs/g
root 837 0.0 0.0 0 0 ? S< 16:07 0:00 [kworker/3:1H]
pi 847 0.1 1.1 19980 11040 ? S 16:07 0:00 openbox --confi
pi 850 0.0 0.8 30372 8484 ? Sl 16:07 0:00 lxpolkit
pi 852 0.3 2.5 94292 24468 ? Sl 16:07 0:00 lxpanel --profi
pi 853 0.1 1.9 78560 18108 ? Sl 16:07 0:00 pcmanfm --deskt
pi 860 0.0 0.0 3700 220 ? Ss 16:07 0:00 /usr/bin/ssh-ag
root 861 0.0 0.7 40944 7396 ? Ssl 16:07 0:00 /usr/lib/policy
pi 876 0.0 0.8 42976 7932 ? Sl 16:07 0:00 /usr/lib/gvfs/g
rtkit 882 0.0 0.2 21376 2084 ? SNsl 16:07 0:00 /usr/lib/rtkit/
root 884 0.0 0.8 59068 7792 ? Ssl 16:07 0:00 /usr/lib/udisks
pi 901 0.0 0.5 29928 5140 ? Sl 16:07 0:00 /usr/lib/gvfs/g
pi 905 0.0 0.5 30032 5412 ? Sl 16:07 0:00 /usr/lib/gvfs/g
pi 910 0.0 0.6 42412 6480 ? Sl 16:07 0:00 /usr/lib/gvfs/g
pi 915 0.0 0.5 30948 5444 ? Sl 16:07 0:00 /usr/lib/gvfs/g
pi 920 0.0 0.0 1912 92 ? S 16:07 0:00 /bin/sh /usr/bi
pi 921 0.0 0.2 5796 1912 ? S 16:07 0:00 /usr/bin/xprop
pi 926 0.0 0.7 60368 7184 ? Sl 16:07 0:00 /usr/lib/gvfs/g
pi 936 0.0 0.6 29696 5920 ? Ssl 16:07 0:00 /usr/lib/menu-c
root 1435 0.0 0.0 0 0 ? S< 16:08 0:00 [kworker/0:1H]
root 1868 0.4 0.5 12076 5172 ? Ss 16:10 0:00 sshd: pi [priv]
pi 1891 0.0 0.3 12076 3516 ? R 16:10 0:00 sshd: pi@pts/0
pi 1893 0.7 0.4 6572 4444 pts/0 Ss 16:10 0:00 -bash
hass 2108 127 2.3 81860 22312 ? Ssl 16:10 0:03 /srv/hass/hass_
pi 2122 0.0 0.2 4740 2184 pts/0 R+ 16:10 0:00 ps -aux
Any help would be appreciated
