Klagio
(Klagio)
September 6, 2019, 7:41am
1
Hi, after having many problems, had to uninstall nginx proxy manager, make various changes, now I have the following
Accessing to HASS
https:// xxx.duckdns.org works,
https:// 192.168.1.10:8123 works (after clicking proceed in browser)
http;// 192.168.1.10:8123 gives ERR_EMPTY_RESPONSE
I am currently using
duckDNS addon (letsencrypt to truie)
Caddy
http:
api_password: !secret api_password
cors_allowed_origins:
- http://192.168.1.10:7080
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
base_url: !secret base_url
port 80 forwarded to port 8123 of 192.168.1.10
port 443 forwarded to port 8123 of 192.168.1.10
But I wish to access HASS also from http://192.168.1.10:8123
Can you guide me to have this access back?
tom_l
September 6, 2019, 8:32am
2
Uninstall duckdns. That will delete the SSL certificates.
Klagio
(Klagio)
September 6, 2019, 8:38am
3
I wish to have both access (as was working before something happened yesterday)
http;// 192.168.1.10;8123
https;//myname.duckdns.org
uninstalling duckdns and reinstalling will do?
tom_l
September 6, 2019, 8:40am
4
No.
Uninstalling duckdns will return http access, reinstalling will disable it.
You can’t have both http and https access simultaneously.
Https works so why not use that?
I use Caddy and get https:// to my duckdns and can use http://ip_address:8123 so if you insist on http it can be done but it’s not obvious what the ‘problem’ is?
Klagio
(Klagio)
September 6, 2019, 9:40am
6
was working up to yesterday just fine. Something happened, and I do not know what
Klagio
(Klagio)
September 6, 2019, 9:41am
7
How?
Below my Caddyfile
https://myname.duckdns.org {
tls /ssl/fullchain.pem /ssl/privkey.pem {
alpn http/1.1
proxy / 192.168.1.10:8123 {
transparent
websocket
log stdout
errors stderr
https://myname-dash.duckdns.org {
alpn http/1.1
proxy / 192.168.1.12:5665 {
transparent
websocket
log stdout
errors stderr
Klagio
(Klagio)
September 6, 2019, 9:45am
8
in the past had various problems either with duckdns or ssl, wish to be able to access, HASSIO HOST, from my LAN also with http, and also from outside my LAN (with a VPN) with http
Here is part of mine…
domain.duckdns.org {
tls {
dns duckdns
log data/requests.log {
rotate_size 50 # Rotate after 50 MB
rotate_age 90 # Keep rotated files for 90 days
rotate_keep 20 # Keep at most 20 log files
rotate_compress # Compress rotated log files in gzip format
header / {
Strict-Transport-Security "max-age=31536000; includeSubdomains"
X-XSS-Protection "1; mode=block"
X-Content-Type-Options "nosniff"
X-Frame-Options "SAMEORIGIN"
Referrer-Policy "same-origin"
-Server
proxy / localhost:8123 {
websocket
transparent
header_upstream Authorization {>Authorization}
And it works with ip:8123 or https
I’m storing logs and using dns instead of port 80
Klagio
(Klagio)
September 6, 2019, 10:12am
10
I did as per your file, but receive error
Using built-in Caddy: Caddy 0.11.1 (unofficial)
Running Caddy: /usr/sbin/caddy -conf /share/caddy/Caddyfile
2019/09/06 12:11:05 /share/caddy/Caddyfile:3 - Error during parsing: Unsupported DNS provider ‘duckdns’
tls {
dns duckdns
header / {
-Server
websocket
transparent
alpn http/1.1
proxy / 192.168.1.10:5665 {
transparent
websocket
log stdout
errors stderr
You need to build a custom Caddy from their site with the duckdns plugin…
If you do that in the zip file you download, there is a file called caddy (no extension) Rename thatbto caddy.bin and put it in the same folder as the caddyfile and make it executable. Then restart the addon. It’s a later version as well.
(NOTE: Building your own is only a few mouse clicks… really easy,)
Klagio
(Klagio)
September 6, 2019, 10:27am
12
you remember how to get there (with terminal) /share/Caddy, where is this directory?
Running Caddy: /share/caddy/caddy.bin -conf /share/caddy/Caddyfile
env: ‘/share/caddy/caddy.bin’: Permission denied
Go one directory up from the file with your configuration.yaml file and there will be a share directory with a caddy folder… it’s the same folder as your caddyfile.
Set the caddy.bin with the same permissions… I think mine is root and make it executable.
The addon… you have to define the env var with your duckdns token like this:
"flags": [
"-agree",
"-email",
"[email protected] "
"env_vars": [
"DUCKDNS_TOKEN=Token-here"
Klagio
(Klagio)
September 6, 2019, 10:36am
14
Ok found
io@ubuntu:/usr/share/hassio/share$ cd caddy
io@ubuntu:/usr/share/hassio/share/caddy$ sudo chmod +x caddy.bin
[sudo] password for io:
but now a different error
Found custom Caddy: Caddy v1.0.3 (h1:i9gRhBgvc5ifchwWtSe7pDpsdS9+Q0Rw9oYQmYUTw1w=)
2019/09/06 12:35:19 /share/caddy/Caddyfile:3 - Error during parsing: Setting up DNS provider ‘duckdns’: duckdns: some credentials information are missing: DUCKDNS_TOKEN
where do I pouit the token?
Hahahahaha!!! We cross-posted… see above.
Klagio
(Klagio)
September 6, 2019, 10:39am
16
Argh … email has to be the duckdns email?
2019/09/06 12:39:05 /share/caddy/Caddyfile:27 - Error during parsing: Unknown directive ‘flags’
myuname.duckdns.org {
tls {
dns duckdns
header / {
-Server
websocket
transparent
"flags": [
"-agree",
"-email",
"env_vars": [
"DUCKDNS_TOKEN=xxxx89e"
That’s the addon configuration - not in your caddyfile…
Email can be anything I believe…
Klagio
(Klagio)
September 6, 2019, 10:43am
18
Ops, ok fixed, all seems ok. But still cant access http://192.168.1.10:8123
19/09/06 12:41:54 [INFO] [xxx.duckdns.org] The server validated our request
2019/09/06 12:41:54 [INFO] [xxx.duckdns.org] acme: Cleaning DNS-01 challenge
2019/09/06 12:41:55 [INFO] [xxx.duckdns.org] acme: Validations succeeded; requesting certificates
2019/09/06 12:41:56 [INFO] [xxx.duckdns.org] Server responded with a certificate.
done.
Serving HTTPS on port 443
https://xxx.duckdns.org
https://xxx-dash.duckdns.org
Serving HTTP on port 80
http://xx.duckdns.org
You need to set the tls part for the sub domain as well.
What is your baseURL in config yaml?
Klagio
(Klagio)
September 6, 2019, 10:47am
20
http:
base_url: https://xxx.duckdns.org:8123
