I am using an esp32cam (connected via USB Adapter ESP32-CAM-MB) and have successfully run the wizard and my ESP is connected to my Wi-Fi network at 192.168.1.10 (However, the name that I see in my router configuration is different).
When trying to upload the modified configuration, it always fails with the error ERROR Connecting to 192.168.1.10:3232 failed: [Errno 111] Connection refused
I have tried to set a static ip, set use_address
(to the ip as well as using <esp-hostname>.localname
), but none of it worked. This is my configuration
esphome:
esp32:
board: esp32cam
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
password: ""
ota:
password: ""
wifi:
ssid: "my-ssid"
password: "ssid-pw"
use_address: 192.168.1.10
manual_ip:
static_ip: 192.168.1.10
gateway: 192.168.1.1
subnet: 255.255.255.0
ap:
ssid: "my-esp32cam Fallback Hotspot"
password: "F6mmLx0rZX60"
captive_portal:
switch:
- platform: gpio
name: "Living Room Dehumidifier"
pin: 5
What could be the issue for that?
