Kant
August 19, 2020, 10:48am
1
!Hello
I have over the air and esp home as plugin in hommeassistent, then I had over the air via arduino IDE on Esp32 and name the Esp32 to pumpe_groome, I had adjust it in esp home and what to connect, the esp over the air via arduino IDE works… But in smart home I get the error… Errno 111 Connection refused… Anyideas?
Hi! I have same problem. Have you solution ?? Sometimes i fix this problem deleting device on ESPHome, compile and upload again using USB.
sjude68
(Sjude68)
June 23, 2021, 2:11pm
5
I have deleted the device in home assistant but the device not found again.
I had reinstalled home assistant and esphome. The previously worked esphome devices got connected and displaying the sensor value. But as i wanted to change something I re complied and uploaded the firmware. After upload I get error 111, connection refused. In home assistant the device sensor value is red but no logger data after upload.
Did you upload the ESPHome firmware to the ESP per cable first?
Compiling a random OTA sketch for the ESP on the Arduino IDE likely won’t work.
Also make sure that it resolves the hostname to the right IP.
Hi there, i’m new in Home Assistant, and i have some trouble getting esp8266 integrated.
Board: ESP8266MOD 12-F from AZ Delivery, Chip SiliconLabs CP2102
The newest Home Assistant is installed on a Raspberry Pi B4, 4GB, 1TB USB-SSD.
My Router is a FritzBox Cable 6690
What i did:
Connected Board via USB-Cable to my PC and later directly to the PI4 (effectless).
started Arduino IDE 2.2.1, ESP8266 connected on COM5 and flashed the code below:
#include <ESP8266WiFi.h>
WiFiServer server(80);
const int BITRATE = 115200; // Übertragungsrate MCU -> serieller Monitor (sM)
const char* SSID = "DGWG4SP"; // WLAN
const char* PASSWORD = "xxxxx"; // WLAN - here not posted
const int SERIAL_DELAY = 1000;
void setup() {
Serial.begin(115200);
while (!Serial) {
delay(SERIAL_DELAY/400);
delay(SERIAL_DELAY);
Serial.println();
// connect to WiFi
Serial.print(F("\nVerbinden mit: "));
Serial.print(SSID);
Serial.print(F(" ."));
WiFi.begin(SSID, PASSWORD);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(F("."));
Serial.println(F("OK"));
Serial.println(F("WiFi verbunden..."));
// Start des Servers
server.begin();
Serial.println(F("Server gestartet..."));
// Print the IP address
Serial.print(F("Diese URL zum Verbinden aufrufen: "));
Serial.print(F("http://"));
Serial.print(WiFi.localIP());
Serial.println(F("/"));
} // ...setup
void loop() {
} // ...loop
opened FritzBox
i saw the ESP8266 in the FritzBox.
I gave it the name ESP-8266-IP50 and a static ip-address (192.168.178.52)
opened Home Assistant, went to the ESP-Home plug-in, clicked on ‘+device’.
YAML:
esphome:
friendly_name: BAD-Sensors
esp8266:
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "kzL5OLwH5NYMp4NxkXL8xUoM156PH9hmVXOxhYAmYB0="
ota:
password: "4b27896cd2b339e4c5589cd13b5ebf07"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.178.52
gateway: 192.168.178.1
subnet: 255.255.255.0
ap:
ssid: "Bad-Sensors Fallback Hotspot"
password: "0BaLccoa68b6"
captive_portal:
LOG:
INFO ESPHome 2023.10.4
INFO Reading configuration /config/esphome/bad-sensors.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esp-8266-ip52 (board: nodemcuv2; framework: arduino; platform: platformio/[email protected] )
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/api_pb2.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/api_pb2_service.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/api_server.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/subscribe_state.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/api/user_services.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/esp8266/core.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/esp8266/gpio.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/esp8266/preferences.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/logger/logger.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/md5/md5.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_component.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_esp32.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_host.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_libretiny.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/mdns/mdns_rp2040.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/network/util.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_backend_arduino_libretiny.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_backend_arduino_rp2040.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/ota/ota_component.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/socket/lwip_sockets_impl.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/socket/socket.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component_libretiny.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/components/wifi/wifi_component_pico_w.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/application.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/color.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/component.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/component_iterator.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/controller.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/entity_base.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/helpers.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/log.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/scheduler.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/string_ref.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/time.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/esphome/core/util.cpp.o
Compiling .pioenvs/esp-8266-ip52/src/main.cpp.o
Generating LD script .pioenvs/esp-8266-ip52/ld/local.eagle.app.v6.common.ld
Compiling .pioenvs/esp-8266-ip52/lib50e/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib50e/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib50e/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib50e/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib50e/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling .pioenvs/esp-8266-ip52/libaf0/Hash/Hash.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/CertStoreBearSSL.cpp.o
Archiving .pioenvs/esp-8266-ip52/lib50e/libESPAsyncTCP-esphome.a
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFi.cpp.o
Archiving .pioenvs/esp-8266-ip52/libaf0/libHash.a
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/WiFiClient.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib67b/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving .pioenvs/esp-8266-ip52/lib67b/libESP8266WiFi.a
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling .pioenvs/esp-8266-ip52/libafe/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling .pioenvs/esp-8266-ip52/libecb/DNSServer/DNSServer.cpp.o
Archiving .pioenvs/esp-8266-ip52/libecb/libDNSServer.a
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/ESP8266mDNS.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/LEAmDNS.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving .pioenvs/esp-8266-ip52/libafe/libESPAsyncWebServer-esphome.a
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib3ff/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_hash/crypto_hash.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_stream/crypto_stream.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/crypto_verify/sodium/verify.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/sodium/codecs.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/sodium/core.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/sodium/runtime.c.o
Compiling .pioenvs/esp-8266-ip52/lib75c/libsodium/sodium/utils.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/openssl/cipher-aesgcm.c.o
Archiving .pioenvs/esp-8266-ip52/lib3ff/libESP8266mDNS.a
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/dh-curve25519.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/hash-blake2b.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/hash-blake2s.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/ref/hash-sha256.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/sodium/dh-curve25519.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/sodium/hash-blake2b.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/backend/sodium/hash-sha256.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/blake2/blake2b.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/blake2/blake2s.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/chacha/chacha.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/donna/curve25519-donna.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/donna/poly1305-donna.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/sha2/sha256.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/sha2/sha512.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/crypto/x25519/x25519.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/cipherstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/dhstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/errors.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/handshakestate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/hashstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/internal.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/names.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/patterns.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/rand_os.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/rand_sodium.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/randstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/signstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/symmetricstate.c.o
Compiling .pioenvs/esp-8266-ip52/liba78/noise-c/protocol/util.c.o
Archiving .pioenvs/esp-8266-ip52/libFrameworkArduinoVariant.a
Archiving .pioenvs/esp-8266-ip52/lib75c/libsodium.a
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Crypto.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Esp-frag.cpp.o
Archiving .pioenvs/esp-8266-ip52/liba78/libnoise-c.a
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Esp-version.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Esp.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/FS.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/FSnoop.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/IPAddress.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/LwipIntf.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/LwipIntfCB.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/MD5Builder.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Print.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Schedule.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/StackThunk.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Stream.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/StreamSend.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Tone.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/TypeConversion.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/Updater.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/WMath.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/WString.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/abi.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/aes_unwrap.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/base64.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/cbuf.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/cont.S.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/cont_util.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_features.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_main.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/crc32.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/debug.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/exc-sethandler.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/flash_hal.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/gdb_hooks.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/heap.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/libb64/cdecode.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/libb64/cencode.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/libc_replacements.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/mmu_iram.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/spiffs_api.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/sqrt32.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/stdlib_noniso.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/time.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/uart.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling .pioenvs/esp-8266-ip52/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving .pioenvs/esp-8266-ip52/libFrameworkArduino.a
Linking .pioenvs/esp-8266-ip52/firmware.elf
RAM: [==== ] 41.3% (used 33860 bytes from 81920 bytes)
Flash: [===== ] 46.2% (used 482085 bytes from 1044464 bytes)
Building .pioenvs/esp-8266-ip52/firmware.bin
esp8266_copy_factory_bin([".pioenvs/esp-8266-ip52/firmware.bin"], [".pioenvs/esp-8266-ip52/firmware.elf"])
======================== [SUCCESS] Took 164.10 seconds ========================
INFO Successfully compiled program.
INFO Connecting to 192.168.178.52
ERROR Connecting to 192.168.178.52:8266 failed: [Errno 111] Connection refused
WHERE IS THE FAULT?
Somebody out there with a going solution ?
Thank in advance.
Stay healthy !
So long
I’ve found a reproducable solution that works for me:
ESP8266 connected via USB-Cable to the RPI
i’ve chosen the Install-Option ‘Plug into the computer running ESP Dashboard’
Stay healthy !
So long
