I don’t have any, I use HACS and the installed modules goes into lovelace resources.
Are things configured both in lovelace resources and in configuration. yaml ?
I don’t know, I followed the instructions.
UPDATE: it looks like we have to choose!
There is stated “While card-mod can be installed as a lovelace resource, some functionality will benefit greatly from it being installed as a frontend module instead.”
… instead …
Yeah as long as it’s in your configuration.yaml then you can remove from resources
I dont have any extra_url in my configuration yaml. Just references in the dashboard.
You can prevent the messages with setting up logger to the following:
logger:
default: warning
logs:
#on every access from the mobile app there is an unought error. we dont want this
frontend.js.latest: critical
Hope this will get fixed
pOpY
Removing the resources broke cards that used it (error cannot find card type, something like this), even though I have the extra_module_url
in the configuration.yaml. So, I put them back.
Removed the extra_module_url
from the configuration.yaml doesn’t cause issue, but it doesn’t fix the Uncaught error
Thank you my friend, that was the problem.
One week now, and error looks gone
