Ricks88
December 22, 2021, 10:16am
1
2021-12-22 11:09:43 ERROR (MainThread) [frontend.js.latest.202112200] https://homeassistant.local:8123/lovelace/overzicht?homescreen=1:0:0 Uncaught
I keep getting these error messages, every time i open home assistant page. or app.
I can not find where they are coming from:
2021-12-22 11:09:43 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.browser_mod_e7ad451e_9671929b (<class 'custom_components.browser_mod.sensor.BrowserModSensor'>) implements device_state_attributes. Please report it to the custom component author.
2021-12-22 11:10:33 ERROR (MainThread) [frontend.js.latest.202112200] https://homeassistant.local:8123/lovelace/overzicht:0:0 Uncaught
And when logging in to the app:
2021-12-22 11:18:13 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.browser_mod_fcdfe6e0_8f8db666 (<class 'custom_components.browser_mod.sensor.BrowserModSensor'>) implements device_state_attributes. Please report it to the custom component author.
2021-12-22 11:18:15 ERROR (MainThread) [frontend.js.latest.202112200] https://192.168.1.100:8123/m-lovelace/overzicht?external_auth=1:0:0 Uncaught
What do they mean, and can i fix them?
dapuzz
(dapuzz)
January 1, 2022, 10:57pm
3
The warning is not related. Can you paste the complete error?
I have this one:
2022-01-01 23:45:15 ERROR (MainThread) [frontend.js.latest.202112200] http://192.168.178.90:8123/frontend_latest/core.47513876.js:1:6969 TypeError: n.callback is not a function. (In ‘n.callback(s.event)’, ‘n.callback’ is undefined)
Is it the same?
its all i can see:
2022-01-03 12:28:05 ERROR (MainThread) [frontend.js.latest.202112290] https://homeassistant.local:8123/lovelace/overzicht?homescreen=1:0:0 Uncaught
2022-01-03 12:28:11 ERROR (MainThread) [frontend.js.latest.202112290] https://homeassistant.local:8123/lovelace/overzicht?homescreen=1:0:0 Uncaught
2022-01-03 12:34:54 ERROR (MainThread) [frontend.js.latest.202112290] https://homeassistant.local:8123/lovelace/overzicht?homescreen=1:0:0 Uncaught
drjjr
(Don )
January 11, 2022, 1:08pm
5
I get the same error whenever I refresh a lovelace panel. Been getting it for a long time. Doesn’t matter which dashboard I refresh.
2022-01-11 07:07:09 ERROR (MainThread) [frontend.js.latest.202112291] http://192.168.0.21:8123/system-monitor/system?kiosk:0:0 Uncaught
Sjorsa
(Sjors)
January 14, 2022, 6:02pm
6
Same issue here, even when I make a completely empty fresh panel, even on different dashboards.
paulius2k
(Paulius2k)
January 26, 2022, 7:21am
7
Something is cached, which does not work normally anymore.
Do a complete reload of the dashboard page with SHIFT+F5.
pOpY
April 23, 2022, 2:46pm
8
Same issue here, mutliple lines of
2022-04-22 20:34:34 ERROR (MainThread) [frontend.js.latest.202204050] https://homeassistant.local:8123/lovelace/0?external_auth=1:0:0 Uncaught
Any hints i can solve the issue?
thx
sender
September 4, 2022, 6:16pm
9
HA_n00b
(HA n00b)
February 10, 2023, 3:47pm
10
BUMP
Logger: frontend.js.latest.202302020
Source: components/system_log/__init__.py:254
First occurred: 10:41:50 (15 occurrences)
Last logged: 16:27:22
* https://ha.XXXXXX.net/lovelace/default_view?external_auth=1:0:0 Uncaught
* http://192.168.XXX.204:8123/lovelace/default_view:0:0 Uncaught
robertjan
(Robertjan)
February 27, 2023, 12:28pm
11
BUMP
Source: components/system_log/init .py:254
First occurred: 26 februari 2023 om 13:23:49 (48 occurrences)
Last logged: 13:19:45
*********:8123/lovelace-tablet/0?hide_sidebar:0:0 Uncaught
*********/lsc2-priscilla/0?kiosk:0:0 Uncaught
*********/lovelace/0:0:0 Uncaught"
conorlap
(Conor)
March 6, 2023, 10:37pm
12
+1 for this!
Edit: removing duplicates from both lovelace resources & configuration.yaml (extra_module_url) solved my issues!
miky_italy
(Michele Canteri)
March 7, 2023, 9:06am
13
Here too.
On every view, if I refresh the browser, the error appears.
miky_italy
(Michele Canteri)
March 7, 2023, 9:10am
14
Found the problem, in lovelace resources I had a duplicate, deleted it, and now no more errors
pOpY
March 7, 2023, 9:36am
15
Can you please go into detail how you solved the issue?
miky_italy
(Michele Canteri)
March 7, 2023, 10:07am
16
Use browser, 3 dots on the top right, edit dashboard, again 3 dots, manage resources
Look for duplicates.
HA_n00b
(HA n00b)
March 7, 2023, 12:09pm
17
There’s no duplicate in my case, and still this issue popping up from time to time.
conorlap
(Conor)
March 7, 2023, 12:21pm
18
Do you have any cards added under ‘frontend’ in your configuration.yaml?
Example:
frontend:
extra_module_url:
- /local/community/frigate-hass-card/frigate-hass-card.js
HA_n00b
(HA n00b)
March 7, 2023, 3:30pm
19
Yes I do, but this is normal I think.
conorlap
(Conor)
March 7, 2023, 3:45pm
20
If they only exist in your configuration.yaml it’s fine but if the same cards are also referenced under Dashboard Resources then I think it causes issues.
