Hello, I’m completely new to Home Assistant and I’ve gotten everything set up the way I want for now, but I can’t seem to get external access to work with the iOS companion app. I bought a domain from NameCheap and followed this guide to set up a Cloudflare tunnel. I can access my Home Assistant perfectly fine with my new domain when I use a browser (desktop and mobile), but when I add the domain to the home assistant companion app, I get an error that says:
bad URL
Error Code:
NSURLErrorDomain -1000
I have googled around but I can’t seem to find a solution to this issue. Does anyone have an idea for what I can try?? Thank you in advance.
Edit: I exported the log file here: 2024-03-21 18:20:06.995 [Info] > Home Assistant Version: 2024.2 Build: 2024.561 - Pastebin.com
