Error -1003 a server with the specified hostname could not be found
I’m getting the following error on multiple devices. Trying to connect through DuckDNS. The local address also doesn’t work. Issue persists on both wifi and mobile.
Any advice would be appreciated.
From time to time, this issue is occuring. At other moments I have no issues.
Same here… but my local network works.
Similar things here. I recently moved from a double NAT configuration to a single NAT and it seems to be a lot more stable. I’ve since had this issue only 1 time in 3 weeks instead of 50% of each day.
