Hello guys! I am trying to build a smart LED-Strip(WS2812) using Esphome and an Esp32, but everytime I try to build, I get the following Error:
Compiling .pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_connection.cpp.o
sh: 1: xtensa-esp32-elf-g++: not found
Compiling .pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_frame_helper.cpp.o
Compiling .pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_pb2.cpp.o
*** [.pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_connection.cpp.o] Error 127
*** [.pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_frame_helper.cpp.o] Error 127
*** [.pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_pb2.cpp.o] Error 127
Compiling .pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_pb2_service.cpp.o
*** [.pioenvs/esphome-web-9f6c10/src/esphome/components/api/api_pb2_service.cpp.o] Error 127
========================== [FAILED] Took 5.70 seconds ==========================
This is the Code of my ESP-Script
esphome:
friendly_name: ESPHome Web 9f6c10
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "TB5bkWDbPhwNh0MlF5HPnBAH7c/KDc4acGz8ccC8hGs="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-9F6C10"
password: "oQpMuLryLxZG"
captive_portal:
I have already tried removing the “type: arduino” line, but it didnt do anything.
My EspHome is Running on Home Assistant, which is running as an OS on a Raspberry Pi 4. Help is appreciated. Sorry if my English is bad!
Thanks for help!
