HI
i have these zwave switches i readout over MQTT in Hassio.
On and Off work fine, but now and then the state isn’t transmitted quite alright. Which is rather inconvenient for other nations in my setup relying on that state obviously.
I therefor want to create a set of shell commands, scripts or what other option would be best to click on a button in Hassio and force read the state of the switches.
I can Curl them like this:
command_state: >-
curl -X POST -d '{"seq":1, "method":"object_prop_get", "arguments":{"oid":"03ad5421", "prop":"state"}}' http://192.168.xxx.xxx/iungo/api_request
ive tried it like this:
sw_audio_auditorium_state_cl:
alias: Audio Auditorium State (cl)
audio_auditorium_state: curl -X POST -d '{"seq":1, "method":"object_prop_get", "arguments":{"oid":"03ad5421", "prop":"state"}}' http://192.168.xxx.xxx/iungo/api_request
but get following errors"
2018-02-25 17:09:46 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: OrderedDict([('alias', 'Audio Auditorium State (cl)'), ('audio_auditorium_state', 'curl -X POST -d \'{"seq":1, "method":"object_prop_set", "arguments":{"oid":"03ad5421", "prop":"command", "value":"on"}}\' http://192.168.xxx.xxx/iungo/api_request')])
, return code: 2
What is wrong, and secondly, is this the best way to do this?
Thanks for looking,
Marius
