Hi, my HomeAssistant (in HASSIO) won’t update:
starting version 3.2.4
17-12-24 16:54:53 INFO (MainThread) [__main__] Initialize Hassio setup
17-12-24 16:54:53 INFO (MainThread) [__main__] Setup HassIO
17-12-24 16:54:53 INFO (SyncWorker_0) [hassio.dock.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.76
17-12-24 16:54:53 INFO (MainThread) [hassio.host_control] Send 'info' to HostControl.
17-12-24 16:54:59 INFO (MainThread) [hassio.host_control] Receive from HostControl: { "type": "resinos", "version": "1.1", "last_version": "1.1", "hostname": "hassio", "features": ["shutdown", "reboot", "update", "hostname"], "os": "GNU/Linux" }.
17-12-24 16:54:59 INFO (SyncWorker_1) [hassio.dock.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.59.2
17-12-24 16:55:00 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository
17-12-24 16:55:00 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
17-12-24 16:55:00 INFO (MainThread) [hassio.addons] Load addons: 27 all - 27 new - 0 remove
17-12-24 16:55:00 INFO (SyncWorker_3) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-rpc_shutdown with version 0.3
17-12-24 16:55:00 INFO (SyncWorker_1) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-google_assistant with version 0.0.3-p5
17-12-24 16:55:00 INFO (SyncWorker_4) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-nginx_proxy with version 0.7
17-12-24 16:55:00 INFO (SyncWorker_0) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-bluetooth_bcm43xx with version 0.7
17-12-24 16:55:00 INFO (SyncWorker_5) [hassio.dock.interface] Attach to image hassioaddons/pi-hole-armhf with version 0.4.0
17-12-24 16:55:00 INFO (SyncWorker_6) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-ssh with version 2.9
17-12-24 16:55:00 INFO (SyncWorker_2) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-letsencrypt with version 1.2
17-12-24 16:55:00 INFO (SyncWorker_5) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-samba with version 2.0
17-12-24 16:55:00 INFO (SyncWorker_13) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-check_config with version 0.7
17-12-24 16:55:00 INFO (SyncWorker_6) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-mosquitto with version 1.0
17-12-24 16:55:00 INFO (SyncWorker_5) [hassio.dock.interface] Attach to image homeassistant/armhf-addon-cec_scan with version 0.2
17-12-24 16:55:00 INFO (MainThread) [hassio.addons] Startup initialize run 1 addons
17-12-24 16:55:00 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
17-12-24 16:55:00 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/hassio-addons/repository repository
17-12-24 16:55:00 INFO (MainThread) [hassio.addons.git] Pull addon https://github.com/home-assistant/hassio-addons repository
17-12-24 16:55:00 INFO (MainThread) [hassio.dns] Start DNS port forwarding for host add-ons
17-12-24 16:55:00 INFO (SyncWorker_9) [hassio.dock.interface] Clean homeassistant/armhf-addon-bluetooth_bcm43xx docker application
17-12-24 16:55:09 INFO (MainThread) [hassio.addons] Load addons: 28 all - 1 new - 0 remove
17-12-24 16:55:11 INFO (SyncWorker_9) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-bluetooth_bcm43xx with version 0.7
17-12-24 16:55:11 INFO (MainThread) [__main__] Run HassIO
17-12-24 16:55:11 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
17-12-24 16:55:12 INFO (MainThread) [hassio.core] Start hassio api on 172.30.32.2
17-12-24 16:55:12 INFO (MainThread) [hassio.addons] Startup system run 1 addons
17-12-24 16:55:12 INFO (SyncWorker_0) [hassio.dock.interface] Clean hassioaddons/pi-hole-armhf docker application
17-12-24 16:55:15 INFO (SyncWorker_0) [hassio.dock.addon] Start docker addon hassioaddons/pi-hole-armhf with version 0.4.0
17-12-24 16:55:15 INFO (MainThread) [hassio.addons] Startup services run 3 addons
17-12-24 16:55:15 INFO (SyncWorker_3) [hassio.dock.interface] Clean homeassistant/armhf-addon-ssh docker application
17-12-24 16:55:15 INFO (SyncWorker_12) [hassio.dock.interface] Clean homeassistant/armhf-addon-samba docker application
17-12-24 16:55:15 INFO (SyncWorker_7) [hassio.dock.interface] Clean homeassistant/armhf-addon-rpc_shutdown docker application
17-12-24 16:55:29 INFO (SyncWorker_7) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-rpc_shutdown with version 0.3
17-12-24 16:55:32 INFO (SyncWorker_12) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-samba with version 2.0
17-12-24 16:55:32 INFO (SyncWorker_3) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-ssh with version 2.9
17-12-24 16:55:32 INFO (SyncWorker_6) [hassio.dock.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
17-12-24 16:55:43 INFO (SyncWorker_6) [hassio.dock.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.59.2
17-12-24 16:55:43 INFO (MainThread) [hassio.addons] Startup application run 2 addons
17-12-24 16:55:43 INFO (SyncWorker_5) [hassio.dock.interface] Clean homeassistant/armhf-addon-google_assistant docker application
17-12-24 16:55:43 INFO (SyncWorker_17) [hassio.dock.interface] Clean homeassistant/armhf-addon-nginx_proxy docker application
17-12-24 16:56:11 INFO (SyncWorker_17) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-nginx_proxy with version 0.7
17-12-24 16:56:15 INFO (SyncWorker_5) [hassio.dock.addon] Start docker addon homeassistant/armhf-addon-google_assistant with version 0.0.3-p5
17-12-24 16:58:34 INFO (SyncWorker_15) [hassio.dock.interface] Update docker 0.59.2 with homeassistant/raspberrypi3-homeassistant:0.60
17-12-24 16:58:34 INFO (SyncWorker_15) [hassio.dock.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.60.
17-12-24 16:59:26 ERROR (SyncWorker_15) [hassio.dock.interface] Can't install homeassistant/raspberrypi3-homeassistant:0.60 -> 404 Client Error: Not Found ("no such image: homeassistant/raspberrypi3-homeassistant:0.60: No such image: homeassistant/raspberrypi3-homeassistant:0.60").
This is the complete log for starting the hassio raspberry and pressing update, the last 3 lines are from the update button. As you can see it says that it can’t find the new image. I have enough free space on my sdcard and I also already tried updating with all addons stopped, but nothing works… Anybody knows how to fix this?
