Error adding ESP8266 in Home Assistant: Socket Operation Failed: Connection_Closed errno=11
Hope someone can help me here! Struggling with a basic setup of an ESP 8266 on home assistant OS.
Its connecting to the WIFI fine, however its failing after install saying:
[22:24:48][D][api:102]: Accepted 10.1.3.168
[22:24:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
Full logs here:
INFO Reading configuration /config/esphome/van-floor-temp.yaml...
INFO Generating C++ source...
INFO Core config or version changed, cleaning build files...
INFO Compiling app...
Processing van-floor-temp (board: nodemcuv2; framework: arduino; platform: platformio/espressif8266 @ 3.2.0)
Library Manager: Installing ottowinter/ESPAsyncTCP-esphome @ 1.2.3
INFO Installing ottowinter/ESPAsyncTCP-esphome @ 1.2.3
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
INFO Installing esphome/ESPAsyncWebServer-esphome @ 2.1.0
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/AsyncTCP-esphome
INFO Installing esphome/AsyncTCP-esphome
Library Manager: Installing esphome/noise-c @ 0.1.4
INFO Installing esphome/noise-c @ 0.1.4
Library Manager: Installing esphome/libsodium @ 1.10018.1
INFO Installing esphome/libsodium @ 1.10018.1
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- ESPAsyncTCP-esphome @ 1.2.3
|-- ESPAsyncWebServer-esphome @ 2.1.0
|   |-- Hash @ 1.0
|   |-- ESP8266WiFi @ 1.0
|-- DNSServer @ 1.1.1
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.4
|   |-- libsodium @ 1.10018.1
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/api_connection.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/api_frame_helper.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/api_pb2.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/api_pb2_service.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/api_server.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/list_entities.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/proto.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/subscribe_state.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/api/user_services.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/captive_portal/captive_portal.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/esp8266/core.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/esp8266/gpio.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/esp8266/preferences.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/logger/logger.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/md5/md5.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/mdns/mdns_component.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/mdns/mdns_esp32_arduino.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/mdns/mdns_esp8266.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/mdns/mdns_esp_idf.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/network/util.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/ota/ota_backend_arduino_esp32.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/ota/ota_backend_arduino_esp8266.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/ota/ota_backend_esp_idf.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/ota/ota_component.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/socket/bsd_sockets_impl.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/socket/lwip_raw_tcp_impl.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/socket/socket.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/web_server_base/web_server_base.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/wifi/wifi_component.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/wifi/wifi_component_esp32_arduino.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/wifi/wifi_component_esp8266.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/components/wifi/wifi_component_esp_idf.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/application.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/color.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/component.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/component_iterator.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/controller.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/entity_base.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/helpers.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/log.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/scheduler.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/esphome/core/util.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/src/main.cpp.o
Generating LD script /data/van-floor-temp/.pioenvs/van-floor-temp/ld/local.eagle.app.v6.common.ld
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/ESPAsyncTCP-esphome/AsyncPrinter.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/ESPAsyncTCP-esphome/ESPAsyncTCP.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/ESPAsyncTCP-esphome/ESPAsyncTCPbuffer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/ESPAsyncTCP-esphome/SyncClient.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/ESPAsyncTCP-esphome/tcp_axtls.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libaf0/Hash/Hash.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/CertStoreBearSSL.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libabd/libESPAsyncTCP-esphome.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFi.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libaf0/libHash.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/ESP8266WiFiScan.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/WiFiClient.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/WiFiServer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/WiFiUdp.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/ESP8266WiFi/enable_wifi_at_boot_time.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/AsyncEventSource.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/AsyncWebSocket.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/WebAuthentication.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/lib67b/libESP8266WiFi.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/WebHandlers.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/WebRequest.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/WebResponses.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/ESPAsyncWebServer-esphome/WebServer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libecb/DNSServer/DNSServer.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libecb/libDNSServer.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/ESP8266mDNS.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/LEAmDNS.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/LEAmDNS_Control.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/lib61c/libESPAsyncWebServer-esphome.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/LEAmDNS_Helpers.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/LEAmDNS_Structs.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/ESP8266mDNS/LEAmDNS_Transfer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_aead/chacha20poly1305/sodium/aead_chacha20poly1305.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_core/ed25519/core_ed25519.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_core/ed25519/core_ristretto255.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_core/ed25519/ref10/ed25519_ref10.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_hash/crypto_hash.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_hash/sha256/cp/hash_sha256_cp.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_hash/sha256/hash_sha256.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_onetimeauth/crypto_onetimeauth.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_onetimeauth/poly1305/donna/poly1305_donna.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_onetimeauth/poly1305/onetimeauth_poly1305.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_scalarmult/crypto_scalarmult.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_scalarmult/curve25519/ref10/x25519_ref10.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_scalarmult/curve25519/scalarmult_curve25519.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_stream/chacha20/ref/chacha20_ref.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_stream/chacha20/stream_chacha20.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_stream/crypto_stream.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/crypto_verify/sodium/verify.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/sodium/codecs.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/sodium/core.c.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/lib3ff/libESP8266mDNS.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/sodium/runtime.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium/sodium/utils.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/openssl/cipher-aesgcm.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/cipher-aesgcm.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/cipher-chachapoly.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/dh-curve25519.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/hash-blake2b.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/hash-blake2s.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/ref/hash-sha256.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/sodium/cipher-aesgcm.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/sodium/cipher-chachapoly.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/sodium/dh-curve25519.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/sodium/hash-blake2b.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/backend/sodium/hash-sha256.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/aes/rijndael-alg-fst.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/blake2/blake2b.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/blake2/blake2s.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/chacha/chacha.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/donna/curve25519-donna-c64.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/donna/curve25519-donna.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/donna/poly1305-donna.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/sha2/sha256.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/sha2/sha512.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/crypto/x25519/x25519.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/cipherstate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/dhstate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/errors.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/handshakestate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/hashstate.c.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/lib149/libsodium.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/internal.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/names.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/patterns.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/rand_os.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/rand_sodium.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/randstate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/signstate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/symmetricstate.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/noise-c/protocol/util.c.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libFrameworkArduinoVariant.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Crypto.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Esp-frag.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Esp-version.cpp.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libc75/libnoise-c.a
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Esp.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/FS.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/FSnoop.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/HardwareSerial.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/IPAddress.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/LwipDhcpServer-NonOS.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/LwipDhcpServer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/LwipIntf.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/LwipIntfCB.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/MD5Builder.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Print.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Schedule.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/StackThunk.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Stream.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/StreamSend.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Tone.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/TypeConversion.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/Updater.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/WMath.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/WString.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/abi.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/aes_unwrap.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/base64.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/cbuf.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/cont.S.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/cont_util.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_eboot_command.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_features.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_flash_quirks.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_flash_utils.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_i2s.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_main.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_non32xfer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_noniso.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_phy.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_postmortem.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_si2c.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_sigma_delta.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_spi_utils.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_timer.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_vm.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_waveform_phase.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring_analog.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring_digital.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/core_esp8266_wiring_shift.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/crc32.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/debug.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/exc-c-wrapper-handler.S.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/exc-sethandler.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/flash_hal.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/gdb_hooks.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/heap.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/hwdt_app_entry.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/libb64/cdecode.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/libb64/cencode.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/libc_replacements.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/mmu_iram.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/reboot_uart_dwnld.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs/spiffs_cache.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs/spiffs_check.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs/spiffs_gc.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/spiffs_api.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/sqrt32.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/stdlib_noniso.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/time.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/uart.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/umm_malloc/umm_info.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/umm_malloc/umm_integrity.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/umm_malloc/umm_local.c.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/umm_malloc/umm_malloc.cpp.o
Compiling /data/van-floor-temp/.pioenvs/van-floor-temp/FrameworkArduino/umm_malloc/umm_poison.c.o
Archiving /data/van-floor-temp/.pioenvs/van-floor-temp/libFrameworkArduino.a
Linking /data/van-floor-temp/.pioenvs/van-floor-temp/firmware.elf
RAM:   [====      ]  41.2% (used 33756 bytes from 81920 bytes)
Flash: [=====     ]  45.5% (used 474789 bytes from 1044464 bytes)
Building /data/van-floor-temp/.pioenvs/van-floor-temp/firmware.bin
esp8266_copy_factory_bin(["/data/van-floor-temp/.pioenvs/van-floor-temp/firmware.bin"], ["/data/van-floor-temp/.pioenvs/van-floor-temp/firmware.elf"])
======================== [SUCCESS] Took 153.95 seconds ========================
INFO Successfully compiled program.
esptool.py v3.3.1
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: a8:48:fa:c1:d1:96
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00000000 to 0x00074fff...
Compressed 478944 bytes to 337891...
Wrote 478944 bytes (337891 compressed) at 0x00000000 in 8.2 seconds (effective 468.8 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[22:18:10]\x90nn$`nr\x8e\x92\x92nrr\x92`p\xf2n\x82r\x8cbbn\xc2nb\xc4\xf2nn'l`\x90nn$`nr\x8e\x92\x92nrl`r\x92\x92nrl`\x9c\xec$l`\xfc\x82n\x92`[I][logger:243]: Log initialized
[22:18:10][C][ota:465]: There have been 0 suspected unsuccessful boot attempts.
[22:18:10][I][app:029]: Running through setup()...
[22:18:10][C][wifi:037]: Setting up WiFi...
[22:18:10][D][wifi:384]: Starting scan...
[22:18:16][D][wifi:399]: Found networks:
[22:18:16][I][wifi:442]: - 'CTMusic' (D2:21:F9:24:19:00) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:444]:     Channel: 3
[22:18:16][D][wifi:445]:     RSSI: -31 dB
[22:18:16][I][wifi:442]: - 'CTMusic' (6A:D7:9A:2F:68:2C) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:444]:     Channel: 1
[22:18:16][D][wifi:445]:     RSSI: -75 dB
[22:18:16][I][wifi:442]: - 'CTMusic' (72:D7:9A:74:91:7D) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:444]:     Channel: 8
[22:18:16][D][wifi:445]:     RSSI: -78 dB
[22:18:16][D][wifi:447]: - 'ECKB-Guest'[redacted] (D2:21:F9:14:19:00) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'ECKB'[redacted] (D0:21:F9:74:19:00) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - ''[redacted] (D2:21:F9:34:19:00) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - ''[redacted] (6A:D7:9A:4F:68:2C) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'ECKB-Guest'[redacted] (6A:D7:9A:1F:68:2C) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'ECKB'[redacted] (68:D7:9A:5F:68:2C) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - ''[redacted] (6A:D7:9A:3F:68:2C) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'ECKB'[redacted] (68:D7:9A:74:91:7D) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'ECKB-Guest'[redacted] (6E:D7:9A:74:91:7D) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - ''[redacted] (76:D7:9A:74:91:7D) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - 'Aduro-56953'[redacted] (52:02:91:F2:69:6B) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - ''[redacted] (6A:D7:9A:48:E0:93) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][D][wifi:447]: - '3FUNiJc375RyZ4FLu5kzGGuXnnVd2RqO'[redacted] (58:B5:68:12:0F:CA) [redacted]β–‚β–„β–†β–ˆ
[22:18:16][I][wifi:255]: WiFi Connecting to 'CTMusic'...
[22:18:17][I][wifi:516]: WiFi Connected!
[22:18:17][C][wifi:360]:   Local MAC: A8:48:FA:C1:D1:96
[22:18:17][C][wifi:361]:   SSID: 'CTMusic'[redacted]
[22:18:17][C][wifi:362]:   IP Address: 10.7.7.28
[22:18:17][C][wifi:363]:   BSSID: D2:21:F9:24:19:00[redacted]
[22:18:17][C][wifi:365]:   Hostname: 'van-floor-temp'
[22:18:17][C][wifi:367]:   Signal strength: -41 dB β–‚β–„β–†β–ˆ
[22:18:17][C][wifi:371]:   Channel: 3
[22:18:17][C][wifi:372]:   Subnet: 255.255.255.0
[22:18:17][C][wifi:373]:   Gateway: 10.7.7.1
[22:18:17][C][wifi:374]:   DNS1: 10.7.7.1
[22:18:17][C][wifi:375]:   DNS2: 0.0.0.0
[22:18:17][D][wifi:525]: Disabling AP...
[22:18:17][C][ota:089]: Over-The-Air Updates:
[22:18:17][C][ota:090]:   Address: van-floor-temp.local:8266
[22:18:17][C][ota:093]:   Using Password.
[22:18:17][C][api:025]: Setting up Home Assistant API server...
[22:18:17][I][app:062]: setup() finished successfully!
[22:18:17][I][app:102]: ESPHome version 2022.10.0 compiled on Oct 25 2022, 22:16:21
[22:18:17][C][wifi:502]: WiFi:
[22:18:17][C][logger:275]: Logger:
[22:18:17][C][logger:276]:   Level: DEBUG
[22:18:17][C][logger:277]:   Log Baud Rate: 115200
[22:18:17][C][logger:278]:   Hardware UART: UART0
[22:18:17][C][captive_portal:088]: Captive Portal:
[22:18:17][C][mdns:100]: mDNS:
[22:18:17][C][mdns:101]:   Hostname: van-floor-temp
[22:18:17][C][api:138]: API Server:
[22:18:17][C][api:139]:   Address: van-floor-temp.local:6053
[22:18:17][C][api:141]:   Using noise encryption: YES
[22:18:48][D][api:102]: Accepted 10.1.3.168
[22:18:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
[22:19:48][D][api:102]: Accepted 10.1.3.168
[22:19:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
[22:20:48][D][api:102]: Accepted 10.1.3.168
[22:20:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
[22:21:48][D][api:102]: Accepted 10.1.3.168
[22:21:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
[22:22:48][D][api:102]: Accepted 10.1.3.168
[22:22:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
[22:23:10][I][ota:109]: Boot seems successful, resetting boot loop counter.
[22:23:48][D][api:102]: Accepted 10.1.3.168
[22:23:48][W][api.connection:071]: 10.1.3.168: Socket operation failed: CONNECTION_CLOSED errno=11
Your HA instance is in a different subnet.
Have you successfully set up an ESPHome device in the 10.7.7.0 subnet before? Is your router configured to route all traffic between those networks? Maybe there is a firewall issue - blocking some ports maybe?
Take a look at this thread on github too Home Assistant API keeps closing connection Β· Issue #3108 Β· esphome/issues Β· GitHub
Hi Nick! Found that thread, did a couple of steps within that thread and its resolved it.
But, new problem. although I can ping it, its showing up as offline in home assistant, any thoughts?
Yeah, I have. I believe the issue was something within home assistant. Deleting the instance in devices & services and then re adding it seems to have resolved that issue.
However now despite the fact that I can ping it, its showing as Offline in the ESP home app on Home Assistant, any thoughts?
Thanks for your responses guys!
Some googling suggests mDNS doesn’t work across subnet boundaries and you need to have static IP address configured on your ESPHome devices.
I think our Unifi network recently went through some updates. I’m wondering if this is whats causing the weird complications that I previously haven’t had. Thanks for pointing me in the right direction. Taking a look. Will update
That depends on the network mask, they could be in the same subnet. But not with a 255.255.255.0
I got this all sorted in the end! Thanks guys.
Do you mind telling how did you sorted out the problem? I’m having the same issue I guess…
same here :frowning:
So there are at least 2 problems described in this thread. Please be specific.
Same here :frowning:
Same, esphome fresh install on 3 different esp8266, My DNS is managed by adguard but deactivate it for debug.
nice way to ask the community for help and then ghost without posting your solution.
I just had this same problem on one of my ESP8266 devices. Deleting it in Settings->Devices and Services->ESPHome fixed it. After deleting it, 2 min later it was auto-discovered. After adding it via auto-discovery, everything worked again.
Hello everyone. Had the same log message hare, even if everything was working fine.
Removed the device, re-added and the warning message disappeared.
Edit: message still shown. Everything working but every 60 second i have that warning:
Socket operation failed: HANDSHAKESTATE_READ_FAILED errno=11
Thanks this worked for me.
I have the same message… have you figured how to fix it & does it effect anything ?
Too you can check that the fixed IP you use, it is reverved on your DHCP server, for your ESP.
