Edit: Solved by updating to 0.51.2
I’m using Home Assistant 0.49.0 (Hassbian on RPI) and have added tellduslive:
tellduslive:
public_key: MYKEYFROMTELLDUS
private_key: MYKEYFROMTELLDUS
token: MYKEYFROMTELLDUS
token_secret: MYKEYFROMTELLDUS
The config file validates and all other stuff in it works.
The log file:
2017-08-16 22:06:44 INFO (MainThread) [homeassistant.setup] Setting up tellduslive
2017-08-16 22:06:45 ERROR (MainThread) [homeassistant.setup] Error during setup of component tellduslive
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
component.setup, hass, processed_config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/tellduslive.py", line 51, in setup
client = TelldusLiveClient(hass, config)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/tellduslive.py", line 71, in __init__
from tellduslive import Client
ImportError: cannot import name 'Client'
2017-08-16 22:06:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service_call_id=3052674576-1, service_data=title=Invalid config, notification_id=invalid_config, message=The following components and platforms could not be set up:
* [tellduslive](https://home-assistant.io/components/tellduslive/)
Please check your config, service=create>
2017-08-16 22:06:45 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
Please check your config; title=Invalid config @ 2017-08-16T22:06:45.530082+02:00>>
