Error after creating a backup pointing to the supervisor log - but this is empty
When I create a backup, everything works fine, but in the end, I get confronted with a dialog saying: “Finished with errors, please check Supervisor log for further details.”
When I check the log, everything is good. All lines are green and for me, nothing points to an error.
23-06-13 11:58:53 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-06-13 11:59:21 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-06-13 12:00:04 INFO (MainThread) [supervisor.host.info] Updating local host information
23-06-13 12:00:05 INFO (MainThread) [supervisor.host.services] Updating service information
23-06-13 12:00:05 INFO (MainThread) [supervisor.host.network] Updating local network information
23-06-13 12:00:05 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-06-13 12:00:05 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-06-13 12:00:32 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-06-13 12:30:32 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-06-13 12:59:21 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-06-13 12:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-06-13 12:59:21 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-06-13 12:59:22 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-06-13 13:00:33 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-06-13 13:02:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
23-06-13 13:02:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repository
23-06-13 13:02:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-06-13 13:02:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-06-13 13:02:40 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-06-13 13:02:44 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-06-13 13:10:58 INFO (MainThread) [supervisor.backups.manager] Found 7 backup files
23-06-13 13:11:31 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug 82fc6729
23-06-13 13:11:31 INFO (MainThread) [supervisor.backups.manager] Backing up 82fc6729 store Add-ons
23-06-13 13:11:31 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_mosquitto
23-06-13 13:11:31 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_mosquitto
23-06-13 13:11:31 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 7ad98f9c_zigbee2mqtt
23-06-13 13:11:31 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 7ad98f9c_zigbee2mqtt
23-06-13 13:11:31 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_vscode
23-06-13 13:12:20 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_vscode
23-06-13 13:12:20 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_influxdb
23-06-13 13:35:10 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_influxdb
23-06-13 13:35:10 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_grafana
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_grafana
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_chrony
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_chrony
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 15d21743_samba_backup
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 15d21743_samba_backup
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_ssh
23-06-13 13:35:11 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_ssh
23-06-13 13:35:11 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-06-13 13:35:11 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
23-06-13 13:36:17 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
23-06-13 13:36:17 INFO (MainThread) [supervisor.backups.manager] Backing up 82fc6729 store folders
23-06-13 13:36:17 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder share
23-06-13 13:36:25 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder share done
23-06-13 13:36:25 INFO (SyncWorker_3) [supervisor.backups.backup] Backing up folder addons/local
23-06-13 13:36:25 INFO (SyncWorker_3) [supervisor.backups.backup] Backup folder addons/local done
23-06-13 13:36:25 INFO (SyncWorker_5) [supervisor.backups.backup] Backing up folder ssl
23-06-13 13:36:25 INFO (SyncWorker_5) [supervisor.backups.backup] Backup folder ssl done
23-06-13 13:36:25 INFO (SyncWorker_1) [supervisor.backups.backup] Backing up folder media
23-06-13 13:36:25 INFO (SyncWorker_1) [supervisor.backups.backup] Backup folder media done
23-06-13 13:36:45 INFO (MainThread) [supervisor.backups.manager] Creating full backup with slug 82fc6729 completed
Where can I figure out, what went wrong?
I have exactly the same problem. At first i thought it was because i put the storage folder on my nas (new feature in 2023.6), but now the problem also occurs when i try to save the backup locally. Have you found a solution yet? I think it has something to do with the 2023.6 update, because before that i made backups very regularly and they always worked.
Today it happened again:
But again supervisor the log is clean:
Any ideas?
Still the same using the next version:
Home Assistant 2023.7.1
Supervisor 2023.08.1
Operating System 10.3
Frontend 20230705.1 - latest
Any news concerning this one? I’m still getting the same weird message currently using 2023.10.
I’m still getting the same weird message - currently using 2023.11.
I wanted to create a separate topic, but the helper pointed me to this one.
Experiencing the same error: “Unknown error, see supervisor logs” when performing backup to remote storage. However, Supervisor logs are green, and show backup as successful.
Supervisor log:
23-11-30 19:56:58 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage addon_repositories
23-11-30 19:56:58 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage docker_config
23-11-30 19:56:58 INFO (MainThread) [supervisor.backups.manager] Creating new full backup with slug 42a78ed8
23-11-30 19:56:58 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage addons
23-11-30 19:56:58 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_ssh
23-11-30 19:56:58 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_ssh
23-11-30 19:56:58 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_motioneye
23-11-30 19:56:59 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_motioneye
23-11-30 19:57:15 INFO (SyncWorker_1) [supervisor.docker.manager] Export image <generator object APIClient._stream_raw_result at 0x7f7f5de110> to /data/tmp/tmp7zg28tiu/image.tar
23-11-30 19:57:34 INFO (SyncWorker_1) [supervisor.docker.manager] Export image <generator object APIClient._stream_raw_result at 0x7f7f5de110> done
23-11-30 19:57:34 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 2ad4c73a_hassos_ssh_configurator_addon
23-11-30 19:59:00 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 2ad4c73a_hassos_ssh_configurator_addon
23-11-30 19:59:00 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage home_assistant
23-11-30 19:59:00 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
23-11-30 20:12:21 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
23-11-30 20:12:21 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage folders
23-11-30 20:12:21 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder share
23-11-30 20:12:24 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder share done
23-11-30 20:12:24 INFO (SyncWorker_3) [supervisor.backups.backup] Backing up folder addons/local
23-11-30 20:12:25 INFO (SyncWorker_3) [supervisor.backups.backup] Backup folder addons/local done
23-11-30 20:12:25 INFO (SyncWorker_2) [supervisor.backups.backup] Backing up folder ssl
23-11-30 20:12:25 INFO (SyncWorker_2) [supervisor.backups.backup] Backup folder ssl done
23-11-30 20:12:25 INFO (SyncWorker_2) [supervisor.backups.backup] Backing up folder media
23-11-30 20:12:25 INFO (SyncWorker_2) [supervisor.backups.backup] Backup folder media done
23-11-30 20:12:25 INFO (MainThread) [supervisor.backups.manager] Backup 42a78ed8 starting stage finishing_file
23-11-30 20:16:38 INFO (MainThread) [supervisor.backups.manager] Creating full backup with slug 42a78ed8 completed
23-11-30 20:18:27 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
I checked the remote storage, and surely enough, the backup file is there.
Should I be worried, or just ignore that error message? How do I make sure?
Still the same here, also after updating to:
23-12-06 11:26:24 INFO (MainThread) [supervisor.backups.manager] Found 2 backup files
23-12-06 11:27:55 INFO (MainThread) [supervisor.backups.manager] Found 2 backup files
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_influxdb
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_grafana
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_grafana
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on a0d7b954_chrony
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon a0d7b954_chrony
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on 15d21743_samba_backup
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon 15d21743_samba_backup
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Building backup for add-on core_ssh
23-12-06 11:38:44 INFO (MainThread) [supervisor.addons.addon] Finish backup for addon core_ssh
23-12-06 11:38:44 INFO (MainThread) [supervisor.backups.manager] Backup bacc8f2f starting stage home_assistant
23-12-06 11:38:44 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
23-12-06 11:39:18 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
23-12-06 11:39:18 INFO (MainThread) [supervisor.backups.manager] Backup bacc8f2f starting stage folders
23-12-06 11:39:18 INFO (SyncWorker_2) [supervisor.backups.backup] Backing up folder share
23-12-06 11:39:27 INFO (SyncWorker_2) [supervisor.backups.backup] Backup folder share done
23-12-06 11:39:27 INFO (SyncWorker_4) [supervisor.backups.backup] Backing up folder addons/local
23-12-06 11:39:27 INFO (SyncWorker_4) [supervisor.backups.backup] Backup folder addons/local done
23-12-06 11:39:27 INFO (SyncWorker_1) [supervisor.backups.backup] Backing up folder ssl
23-12-06 11:39:27 INFO (SyncWorker_1) [supervisor.backups.backup] Backup folder ssl done
23-12-06 11:39:27 INFO (SyncWorker_0) [supervisor.backups.backup] Backing up folder media
23-12-06 11:39:27 INFO (SyncWorker_0) [supervisor.backups.backup] Backup folder media done
23-12-06 11:39:27 INFO (MainThread) [supervisor.backups.manager] Backup bacc8f2f starting stage finishing_file
23-12-06 11:40:15 INFO (MainThread) [supervisor.backups.manager] Creating full backup with slug bacc8f2f completed
23-12-06 11:40:48 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 12:10:49 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-06 12:13:23 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-12-06 12:13:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-06 12:13:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-12-06 12:13:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-12-06 12:14:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
23-12-06 12:14:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repository
23-12-06 12:14:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
23-12-06 12:14:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
23-12-06 12:14:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
23-12-06 12:14:50 INFO (MainThread) [supervisor.store] Loading add-ons from store: 74 all - 0 new - 0 remove
23-12-06 12:40:49 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 12:52:08 INFO (MainThread) [supervisor.backups.manager] Found 3 backup files
23-12-06 12:52:28 INFO (MainThread) [supervisor.api.backups] Downloading backup bacc8f2f
23-12-06 12:54:54 INFO (MainThread) [supervisor.backups.manager] Removed backup file e22a24aa
23-12-06 12:54:54 INFO (MainThread) [supervisor.backups.manager] Removed backup file 4d5fe90b
23-12-06 12:54:54 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
23-12-06 13:10:49 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-12-06 13:13:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-12-06 13:14:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-12-06 13:28:07 INFO (MainThread) [supervisor.host.info] Updating local host information
23-12-06 13:28:08 INFO (MainThread) [supervisor.host.services] Updating service information
23-12-06 13:28:08 INFO (MainThread) [supervisor.host.network] Updating local network information
23-12-06 13:28:08 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-12-06 13:28:08 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-12-06 13:40:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 14:10:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
23-12-06 14:13:24 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-12-06 14:40:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
I guess nobody cares, because it does not hurt.
