HASS won’t start after updating to 0.67, already tried to uninstall homeassistant but after reinstall the error is still there.
C:\Users\Jeroen\AppData\Roaming\.homeassistant>py -m homeassistant --open-ui
File "C:\Users\Jeroen\AppData\Local\Programs\Python\Python37\lib\site-packages\homeassistant\__main__.py", line 11, in <module>
from typing import Optional, List
File "C:\Users\Jeroen\AppData\Local\Programs\Python\Python37\lib\site-packages\typing.py", line 1347, in <module>
class Callable(extra=collections_abc.Callable, metaclass=CallableMeta):
File "C:\Users\Jeroen\AppData\Local\Programs\Python\Python37\lib\site-packages\typing.py", line 1003, in __new__
self._abc_registry = extra._abc_registry
AttributeError: type object 'Callable' has no attribute '_abc_registry'
Sorry for the late response, I fixed it by deleting all site-packages from de home assistant folder and just do a reinstall.
This was a fix for multiple updates.
I’m trying to get HA to run on Windows 10 for the first time and I tried both “python -m homeassistant --open-ui” and “py -m homeassistant --open-ui”. Neither worked. received the same error referred to previously AttributeError: type object ‘Callable’ has no attribute ‘_abc_registry’.
