Ive been a bit slack with updating HA lately (last update was couple/few months ago). But when i tried updating recently, my zigbee2mqtt has been failing to start. I can run it just fine with the older version (im running on a VM through proxmox, so i can easily just roll back which i have done - rolled back to old version yet again while i hear some suggestions).
For context im a bit noob at this, so bare with me. i use a athom ethernet zigbee adaptor/coordinator (the cordinator is a standalone device thats connected to my local network via ethernet, and zigbee2mqtt connects to it via ip/port). The adaptor/coordinator is up and running and i can still connect to its tasmota interface via IP.
After updating zigbee2mqtt, when i run it, i get the following error:
[2024-07-08 23:36:02] info: z2m: Logging to console, file (filename: log.log)
[2024-07-08 23:36:02] info: z2m: Starting Zigbee2MQTT version 1.39.0 (commit #unknown)
[2024-07-08 23:36:02] info: z2m: Starting zigbee-herdsman (0.50.1)
[2024-07-08 23:36:02] info: zh:zstack:znp: Opening TCP socket with 192.168.1.102:8888
[2024-07-08 23:36:02] info: zh:zstack:znp: Socket connected
[2024-07-08 23:36:02] info: zh:zstack:znp: Socket ready
[2024-07-08 23:36:02] info: zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2024-07-08 23:36:03] info: zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2024-07-08 23:36:21] error: z2m: Error while starting zigbee-herdsman
[2024-07-08 23:36:21] error: z2m: Failed to start zigbee
[2024-07-08 23:36:21] error: z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-07-08 23:36:21] error: z2m: Exiting...
[2024-07-08 23:36:21] error: z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:101:27)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:129:29)
at Zigbee.start (/app/lib/zigbee.ts:63:27)
at Controller.start (/app/lib/controller.ts:139:27)
at start (/app/index.js:154:5)
Im not entirely sure whats happened here. Any ideas? Current version of zigbee2mqtt 1.37.0-1 works fine, the new 1.39 has the above error.
password and device IDs removed. I have about 50 odd devices, ive removed those from the code above. 192.168.1.102 is the ip for the zigbee gateway (http://192.168.1.102/ brings me to the usual tasmota config page for the gateway).
As i said earlier, z2m 1.37 works perfectly fine and i have no issues at all, 1.39 throws the above error (1.38 i believe also had the same error - i think i tried updating two weeks ago and had the same issue - luckily i can easily roll back).
I still dont really have a solution for this. After a while i realised it had very little to do with the version. There must be something else wrong here but i cant quite figure out what.
Sometime when i restart HA (reguardless of the version), Z2M fails with the same error as above (im now at 1.40.0-1). Sometimes it starts up just fine. So im now forced to restart home assistant several times till z2m works. i really cant see a pattern here. Yesterday i restarted few times with no issue. Today, i restarted few times and i cant get z2m start at all.
Oh, haha good to know. I guess some of my HA restarts have been wasteful then =/ but yeah, when the issue does happen, I tend to restart the machine, restart ha (well that probably never did anything then) and restart z2m several times till the problem resolves it self.
So, i have had another member @alp-by message me a while ago also having the same/identical issue. We looked at how similar our setups were, and turned out it was very similar:
both of us were running our HA on VMs (im using proxmox and they were using vmware)
After all this time, i couldnt really find a proper solution. Recently i decided to change my coordinator to a SMLIGHT SLZB-06 (also an ethernet based zigbee coordinator), and somehow i no longer have the same issue (its been a month ish, and i have done dozens of full reboots, and no issue connecting).
So, if anyone is having the same issue, im just leaving here the results of my investigation, and what solved the issue for me. Hope it helps
Same here problem happened today with the SMLIGHT SLZB-06 had been running great for 6 days and then just failed to connect. I had to re-flash the SLZB-06 for ZB2MQTT to re-connect to the network co-ordinator. Very weird.
