I’m running homeassistant 0.60.0 in an python3.4 venv on raspbian and it works fine so far.
Now I wanted to ugprade to 0.64.3 and after the upgrade finished startup brings up this error:
systemd[1]: Starting Home Assistant...
systemd[1]: Started Home Assistant.
hass[24331]: Traceback (most recent call last):
hass[24331]: File "/srv/homeassistant/homeassistant_venv/bin/hass", line 11, in <module>
hass[24331]: sys.exit(main())
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/__main__.py", line
hass[24331]: exit_code = setup_and_run_hass(config_dir, args)
hass[24331]: from homeassistant import bootstrap
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py", lin
hass[24331]: from homeassistant import (
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/config_entries.py"
hass[24331]: from .setup import async_setup_component, async_process_deps_reqs
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/setup.py", line 9,
hass[24331]: from homeassistant import requirements, core, loader, config as conf_util
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/requirements.py",
hass[24331]: import homeassistant.util.package as pkg_util
hass[24331]: File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/util/package.py",
hass[24331]: from pip.locations import running_under_virtualenv
hass[24331]: ImportError: No module named 'pip.locations'
I tried downgrading back to 0.60.0 but the error stays.
Any ideas how I can get it back running, preferable with the 0.60.0 version?
Thanks!
