Error after upgrade to 0.84.2
Hello.
I just upgraded to v0.84.2 and am getting the following error message. What’s going on?
2018-12-15 11:03:49 INFO (MainThread) [homeassistant.components.http.view] Serving /api/websocket to 172.17.0.2 (auth: False)
2018-12-15 11:03:49 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139640661972808] Error handling message: {'id': 153, 'type': 'subscribe_events'}
 File "/usr/src/app/homeassistant/components/websocket_api/connection.py", line 66, in async_handle
   handler(self.hass, self, schema(msg))
 File "/usr/src/app/homeassistant/components/websocket_api/commands.py", line 102, in handle_subscribe_events
   if not connection.user.is_admin:
AttributeError: 'NoneType' object has no attribute 'is_admin'
Further to this, I’m running HA in a docker container on Ubuntu. I’m also running containers for MQTT and appdaemon. The error seems to be related to docker’s internal network, as appdaemon can no longer connects to HA. Must have been a breaking change I missed? Something in the auth system?
Thanks.
Appdaemon requires a token instead of the api password as of 84.
And I guess these will be useful. My appdaemon.yaml file:
secret: /config/secrets.yaml
log:
  logfile: /conf/appdaemon/appdaemon.log
  errorfile: /conf/appdaemon/appdaemon.log
  accessfile: /conf/appdaemon/appdaemon.log
  log_generations: 3
  log_size: 500000
appdaemon:
  threads: 10
  disable_apps: 1
  plugins:
    HASS:
      type: hass
      ha_url: http://192.168.2.243:8123
      ha_key: xxxxxxxxx
hadashboard:
  dash_url: http://192.168.2.243:5050
  dash_dir: /conf/dashboards
docker-compose.yaml
version: '3.7'
services:
  mqtt:
    image: eclipse-mosquitto
    container_name: MQTT
    restart: always
    ports:
      - 1883:1883
    volumes:
      - /home/jcuccia/docker_files/mqtt/data:/mosquitto/data
      - /home/jcuccia/docker_files/mqtt/config:/mosquitto/config
      - /home/jcuccia/docker_files/mqtt/log:/mosquitto/log
    network_mode: host
  homeassistant:
    image: homeassistant/home-assistant
    container_name: home-assistant
    restart: always
    depends_on:
      - mqtt
    volumes:
      - /home/jcuccia/docker_files/hass:/config
      - /etc/localtime:/etc/localtime:ro
      - /root/.ssh:/root/.ssh
    devices:
      - /dev/ttyACM0:/dev/ttyACM0
    network_mode: host
And my script to start appdemon, which I can’t get to work with docker-compose):
docker run --name=appdaemon -d -p 5050:5050 \
  --restart=no \
  -e HA_URL="http://192.168.2.243:8123" \
  -e HA_KEY="xxxxxxxx" \
  -v /home/jcuccia/docker_files/hass/:/conf \
  acockburn/appdaemon:latest
Thanks again.
This is sorted out. I changed AppDaemon’s access to a long-lived token and added location info (latitude/longitude/elevation) to appdaemon.yaml and it’s all working.
Yes, that fixed it, thanks.
Awesome. I checked the release notes on 84 and didn’t see anything about this. Go figure. Oh well, we are both back up and running! :slight_smile:
@jcuccia posted appdaemon.yaml is the one working fine? If not could you please post the running one? Not sure where to define token instead of password.
This one works.
log:
  log_generations: 3
  log_size: 500000
appdaemon:
  threads: 10
  disable_apps: 1
  plugins:
    HASS:
      type: hass
      token: xxxxxxxxxxxxxxxxxxxxxxxxx
hadashboard:
Thanks man.
