Today I was presented with ESPHome update from 2025.12.4 to 2025.12.5. That proceeded fine. Then I tried to update my HA Voice Preview and am getting this error:
INFO ESPHome 2025.12.5
INFO Reading configuration /config/esphome/home-assistant-voice-0a1632.yaml...
INFO Updating https://github.com/esphome/home-assistant-voice-pe@dev
INFO Updating https://github.com/esphome/esphome@f5c1a8111df78e32d07d7a7bb800018808cdc0e7
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq/#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
Failed config
sendspin: [source /data/packages/dc43710d/home-assistant-voice.yaml:1556]
not a valid value.
task_stack_in_psram: True
kalman_process_error: 0.01
I tried cleaning install files and I get the exact same error. I don’t know where to go from here. Anyone else experiencing this?
Sorry, but I still don’t know what to do. The file you link to is on Github. I don’t think I can edit that file, can I? Do I need to download it, put it somewhere, then tweak it?
I must say, I’m becoming less and less of a fan of ESP home as time passes. Ugh!
Did you “take control” of HAVPE?
If yes, you need to edit yaml changing “packages” or “external components” using previously posted examples. Maybe post your yaml if you don’t know.
If you did not “take control” you should be able to update now. If not it likely will work by now.
Honestly if your voice device is working I would just wait a week as there was no significant change for HAVPE. I honestly would not update if I was not curious about cause of this issue?
