Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/update.py:305
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 6 de octubre de 2023, 12:04:58 (12 occurrences)
Last logged: 16:23:08
[140066599152384] Error updating Home Assistant Core Another job is running for job group home_assistant_core
[140066601961600] Error updating Home Assistant Core Another job is running for job group home_assistant_core
[140066569879808] Error updating Home Assistant Core Another job is running for job group home_assistant_core
[140066414622704] Error updating Home Assistant Core Another job is running for job group home_assistant_core
[140066570245872] Error updating Home Assistant Core Another job is running for job group home_assistant_core
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 303, in async_install
await async_update_core(self.hass, version=version, backup=backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/handler.py”, line 51, in _wrapper
raise HassioAPIError(data[“message”])
homeassistant.components.hassio.handler.HassioAPIError: Another job is running for job group home_assistant_core
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 199, in handle_call_service
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1820, in async_call
task.result()
File “/usr/src/homeassistant/homeassistant/core.py”, line 1857, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 216, in handle_service
await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 798, in entity_service_call
future.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 977, in async_request_call
await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 838, in _handle_entity_call
await result
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 156, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 417, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/hassio/update.py”, line 305, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Core Another job is running for job group home_assistant_core
