Hello people!
I added the Alert component in my configuration file as follows:
https://hastebin.com/hunasegovi.makefile
If I understood correctly he would run every two minutes.
Only it is running every 3 hours and 2 minutes.
Hello people!
This is usually caused by the time not being set correctly somewhere along the line.
Check that your timezone is correct, and the time on the device is right.
I think @Tinkerer worked it out originally. Hopefully he can clarify.
The Home Assistant was configured for America and the operating system for US
I changed the operating system to America and sent it correctly.
Thanks!
Yup, timezones being different are the cause of incorrect delays (in my case, it fired dozens of times a second).
This is why the component page now warns about that.
