Does anyone know how to get rid of all these errors in my Home Assistant log?
2020-07-08 15:46:04 INFO (SyncWorker_1) [plexapi] Testing 2 resource connections..
2020-07-08 15:46:07 ERROR (Thread-6) [plexapi] http://192.168.1.166:32500: HTTPConnectionPool(host='192.168.1.166', port=32500): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f947e9ce150>, 'Connection to 192.168.1.166 timed out. (connect timeout=3)'))
2020-07-08 15:46:07 ERROR (Thread-7) [plexapi] http://192.168.1.166:32500: HTTPConnectionPool(host='192.168.1.166', port=32500): Max retries exceeded with url: /resources (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f947e9d23d0>, 'Connection to 192.168.1.166 timed out. (connect timeout=3)'))
2020-07-08 15:46:07 INFO (SyncWorker_1) [plexapi] Resource connection ERR (3s): http://192.168.1.166:32500?X-Plex-Token=None
2020-07-08 15:46:07 ERROR (SyncWorker_1) [homeassistant.components.plex.server] plex.tv resource connection failed: Alyssa's Tablet
2020-07-08 15:46:20 ERROR (MainThread) [homeassistant.util.logging] Exception in async_call when dispatching 'plex_update_platforms_signal.64481c1408267cf1fb58257bd667c863b7bdf79b': ()
File "/usr/src/homeassistant/homeassistant/helpers/debounce.py", line 60, in async_call
await self.hass.async_add_job(self.function) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/plex/server.py", line 348, in _async_update_platforms
session_username = session.usernames[0]
File "/usr/local/lib/python3.7/site-packages/plexapi/base.py", line 296, in __getattribute__
value = super(PlexPartialObject, self).__getattribute__(attr)
AttributeError: 'Clip' object has no attribute 'usernames'
2020-07-08 15:48:50 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'006310a1ad4fa57e' (b'4fa5' != b'da69')
2020-07-08 15:55:46 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 275, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp\_http_parser.pyx", line 523, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: invalid HTTP method
2020-07-08 16:00:52 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'0013e0a1adee827e' (b'ee82' != b'7b4e')
2020-07-08 16:08:34 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'00029bb1ed542e14b25c954b65ab5592e162e0d06212316e82c6c64389fc7e3fa71f6d7e' (b'1f6d' != b'5d1f')
2020-07-08 16:35:29 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'0070dda1adab787e' (b'ab78' != b'3eb4')
2020-07-08 16:43:11 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'006390a1ad74ff7e' (b'74ff' != b'e133')
2020-07-08 17:00:14 ERROR (bellows.thread_0) [bellows.uart] CRC error in frame b'000607a1ad6cc17e' (b'6cc1' != b'f90d')
2020-07-08 17:43:17 INFO (SyncWorker_2) [plexapi] Testing 2 resource connections..
2020-07-08 17:43:17 INFO (SyncWorker_2) [plexapi] Resource connection OK (0s): http://192.168.1.166:32500?X-Plex-Token=None
2020-07-08 17:43:17 INFO (SyncWorker_2) [plexapi] Connecting to Resource: http://192.168.1.166:32500?X-Plex-Token=None
Im running Home Assistant in a VirtualBox VM. I can see that some of those errors are related to the Plex integration. However, I don’t really have many options to change or select in the integration. Also, I’m not even sure if it’s related to the other CRC errors I’m getting.
PS: I am using a HUSBZB-1 USB Hub
EDIT: I just notice the line in my log below. I’m not exactly sure where to report this:
2020-07-08 19:52:44 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue for plex doing I/O at homeassistant/components/plex/sensor.py, line 119: if sess.year is not None:
EDIT: I just created an issue for this:
https://github.com/home-assistant/core/issues/37670
