I am calling a script like this:
service: script.speaker_radio_play
speaker: "woonkamer"
This is the content of the script:
speaker_radio_play:
alias: Speaker Radio Afspelen
sequence:
- service: media_player.play_media
data_template:
entity_id: media_player.speaker_{{ speaker }}
media_content_id: >
{% if is_state("input_select.radio_zender_{{ speaker }}", "3FM") %} http://icecast.omroep.nl/3fm-bb-mp3
{% elif is_state("input_select.radio_zender_{{ speaker }}", "Sky Radio") %} http://playerservices.streamtheworld.com/api/livestream-redirect/SKYRADIO.mp3
{% endif %}
media_content_type: 'audio/mp4'
However, this does not work. I receive the following error in the log:
2021-06-02 09:54:59 ERROR (MainThread) [homeassistant.components.script.speaker_radio_play] Speaker Radio Afspelen: Error executing script. Unexpected error for call_service at pos 1: string index out of range
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 366, in _async_step
await getattr(self, handler)()
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 566, in _async_call_service_step
await service_task
File "/usr/lib/python3.9/site-packages/homeassistant/core.py", line 1481, in async_call
task.result()
File "/usr/lib/python3.9/site-packages/homeassistant/core.py", line 1516, in _execute_service
await handler.job.target(service_call)
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/entity_component.py", line 213, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/service.py", line 658, in entity_service_call
future.result() # pop exception if have
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/entity.py", line 726, in async_request_call
await coro
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/service.py", line 695, in _handle_entity_call
await result
File "/usr/lib/python3.9/site-packages/homeassistant/components/cast/media_player.py", line 459, in async_play_media
if media_id[0] == "/":
IndexError: string index out of range
2021-06-02 09:54:59 ERROR (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Error executing script. Unexpected error for call_service at pos 1: string index out of range
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 569, in _async_call_service_step
await self._async_run_long_action(service_task)
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 530, in _async_run_long_action
long_task.result()
task.result()
File "/usr/lib/python3.9/site-packages/homeassistant/components/script/__init__.py", line 278, in service_handler
await script_entity.async_turn_on(
File "/usr/lib/python3.9/site-packages/homeassistant/components/script/__init__.py", line 382, in async_turn_on
await coro
File "/usr/lib/python3.9/site-packages/homeassistant/components/script/__init__.py", line 404, in _async_run
return await self.script.async_run(variables, context)
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 1212, in async_run
await asyncio.shield(run.async_run())
File "/usr/lib/python3.9/site-packages/homeassistant/helpers/script.py", line 348, in async_run
await self._async_step(log_exceptions=False)
await service_task
task.result()
await coro
await result
2021-06-02 09:54:59 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [140130171728608] Error handling message: Unknown error
File "/usr/lib/python3.9/site-packages/homeassistant/components/websocket_api/decorators.py", line 21, in _handle_async_response
await func(hass, connection, msg)
File "/usr/lib/python3.9/site-packages/homeassistant/components/websocket_api/commands.py", line 482, in handle_execute_script
await script_obj.async_run(msg.get("variables"), context=context)
long_task.result()
task.result()
await coro
await service_task
task.result()
await coro
await result
Any suggestions wabout what I’m doing wrong?
Thanks!
