Hi all,
I’m using HA in a RPi3 with AIO installer since 9 months around and I almost found help to my problems with the config file in this forum, but this time I really can’t get what it’s going on, so I please ask for your help;
Around one week ago I update/upgrade my system (Raspbian) and since then every time that I type “upgrade it again” the console shows this;
(I know this is not a forum to ask for help regarding Raspbian, but I don’t know if it related with my HA Problem) (and I already tried the same upgrade stopping mosquitto but the response is the same)
Even with that message, mosquitto runs great and actually I’m using it as my broker for DHT22 and door sensors without any problem being able to use the readings in HA
The problem is that on the last days I’m getting too often the following error when I’m trying to log into my HA (and actually that password page should not appear as I’m in LAN and is marked as “trusted netwoked” and in the pasted works great
The lattitude on my config file is ok,
This HA message dissapear some seconds after is showed and if I attemp to log in with the corrrct passwd the image change to “loading data” indefinitely
About the log…the only messages that I’m getting are;
17-01-12 04:52:01 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 04:52:04 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 1 s
(Several of this last ones, almost every 30 seconds and that’s it)
And sometimes also I got random errors like “darksky” is taking too much, or sensor.xx is taking too much
Finally the only “pattern” that I’ve found is that some times if I desactivate the "zone"s the error do not appear and actually the random errors also dissapear (but sometimes even if I #comment all the zones and latitude info in the config file the error persist specially when the log doesn’t have more than …“around”… +30 entries
And the only way it seems to completly dissapear is deleting the “sensor.statistics”
17-01-12 06:08:03 homeassistant.components.device_tracker: Duplicate device MAC addresses detected E8:50:8B:18:90:0D
17-01-12 06:08:30 homeassistant.components.sensor.statistics: mean requires at least one data point
17-01-12 06:08:39 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 06:09:01 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 06:09:02 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 06:09:02 homeassistant.helpers.condition: Value cannot be processed as a number: unknown
17-01-12 06:09:31 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 06:09:32 homeassistant.components.sensor.statistics: variance requires at least two data points
17-01-12 06:10:25 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 1 s
17-01-12 06:10:26 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 2 s
17-01-12 06:11:58 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 1 s
17-01-12 06:11:59 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 2 s
17-01-12 06:13:30 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 1 s
17-01-12 06:13:32 homeassistant.components.mqtt: Disconnected from MQTT (1). Trying to reconnect in 2 s
So I really don’t understand what is happening and I will really appreciate your time
