Error code
Can anyone tell me what this error is and how to fix it?
Logger: homeassistant.components.zha.core.channels.base
Source: components/zha/core/channels/base.py:486
Integration: Zigbee Home Automation (documentation, issues)
First occurred: November 9, 2022 at 8:15:58 PM (76 occurrences)
Last logged: 6:21:52 PM
[0xE25F:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), TimeoutError(), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’)]
[0xE25F:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’)]
[0xE25F:11:0x0006]: async_initialize: all attempts have failed: [DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’)]
[0xE25F:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), TimeoutError(), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’)]
[0xE25F:11:0x0008]: async_initialize: all attempts have failed: [DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), DeliveryError(‘Request failed after 5 attempts: <Status.NWK_INVALID_REQUEST: 194>’), TimeoutError()]
It seems that ZHA/zigpy is probably having problems talking to your Zigbee Coordination adapter, but not enough with that log, you are (always) also going to have to provide a description of your setup and what you are doing. E.g. what would someone else need to have and do to replicate what you see? For example, you did not write any details about your Zigbee Coordination adapter or how ZHA is connecting to it. If you are using a Zigbee Coordination adapter over WiFi then advice to not do so and instead buy an USB or wired Ethernet adapter → https://www.home-assistant.io/integrations/zha#warning-about-wi-fi-based-zigbee-to-serial-bridgesgateways Other than that all can recommend is to read and follow this best practice guide → Generic best practice tips on improving Zigbee network range and general stability · zigpy/zigpy Wiki · GitHub
UPDATE! Follow these tips first → Zigbee networks: how to guide for avoiding interference + optimizing using Zigbee Router devices (repeaters/extenders) to get best possible range and coverage
Thank you for reply.
