Error - Command line switches - Command works in terminal but not HA
Lets see if I figure this out before getting a reply!
FYI I’m a noob…
So I’ve been working to get my Radio Thermostat CT80 working with HA.
The current mode and current temperature report to HA. Sweet.
Now I’m making a very dumb command switch to turn the thermostat to OFF mode and another to switch it to HEAT mode and set the temp to 72*F.
The curl commands quoted below work in terminal… The thermostat behaves as anticipated!
Inside config.yaml they bring errors.
 thermostat_off:
   command_on: 'curl "http://192.168.1.123/tstat" -d '{"tmode": 0}' -X POST # OFF'
 thermostat_to_seventy_two:
   command_on: 'curl -d '{"tmode":1,"t_heat":72}' http://192.168.1.123/tstat'
Errors:
Configuration invalid
Error loading /config/configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 111, column 8 expected <block end>, but found ‘{’ in “/config/configuration.yaml”, line 111, column 59
At least one problem is you’re not using quoting correctly. Your command strings are quoted overall by single-quote characters. So it’s ok to use double-quote characters inside the string. But you’re also trying to use single-quote characters inside the string. That won’t work the way you’re doing it. In YAML, you can “escape” a single-quote character inside a string that is enclosed in single-quotes by entering two single-quote characters together. So, try this:
 thermostat_off:
   command_on: 'curl "http://192.168.1.123/tstat" -d ''{"tmode": 0}'' -X POST # OFF'
   command_on: 'curl -d ''{"tmode":1,"t_heat":72}'' http://192.168.1.123/tstat'
Good stuff! Thank you that worked :sunglasses:
I’m just wondering, as its not got an off command, because each off state might be different regarding where and when the command happened.
Does HA do a momentary push button option?
The buttons currently stay in the on position once I fire new commands.
Thanks again for your help so far :+1:
