Hi, the device is a tuya remote with esp32c3 to control my mitsubishi ac.
The mitsubishi climate component didn’t work so I wanted to switch to heatpumpir.
But I keep getting this error, no matter which mitsubishi protocol i selected.
Error logs:
|-- IRremoteESP8266 @ 2.7.12
Compiling .pioenvs/esp32c3-remote/src/main.cpp.o
Compiling .pioenvs/esp32c3-remote/libbe5/IRremoteESP8266/IRrecv.cpp.o
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp: In member function 'uint32_t IRrecv::ticksLow(uint32_t, uint8_t, uint16_t)':
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:926:8: error: no matching function for call to 'max(int32_t, int)'
0));
In file included from /data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/algorithm:61,
from /data/cache/platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:162,
from .piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.h:10,
from .piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:6:
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:219:5: note: candidate: 'template<class _Tp> const _Tp& std::max(const _Tp&, const _Tp&)'
max(const _Tp& __a, const _Tp& __b)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:219:5: note: template argument deduction/substitution failed:
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:926:8: note: deduced conflicting types for parameter 'const _Tp' ('long int' and 'int')
0));
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:265:5: note: candidate: 'template<class _Tp, class _Compare> const _Tp& std::max(const _Tp&, const _Tp&, _Compare)'
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:265:5: note: template argument deduction/substitution failed:
0));
In file included from /data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/algorithm:62,
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3462:5: note: candidate: 'template<class _Tp> _Tp std::max(std::initializer_list<_Tp>)'
max(initializer_list<_Tp> __l)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3462:5: note: template argument deduction/substitution failed:
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:926:8: note: mismatched types 'std::initializer_list<_Tp>' and 'long int'
0));
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3468:5: note: candidate: 'template<class _Tp, class _Compare> _Tp std::max(std::initializer_list<_Tp>, _Compare)'
max(initializer_list<_Tp> __l, _Compare __comp)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3468:5: note: template argument deduction/substitution failed:
0));
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp: In member function 'bool IRrecv::matchAtLeast(uint32_t, uint32_t, uint8_t, uint16_t)':
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:1009:77: error: no matching function for call to 'min(uint32_t&, unsigned int)'
return measured >= ticksLow(std::min(desired, MS_TO_USEC(irparams.timeout)),
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:195:5: note: candidate: 'template<class _Tp> const _Tp& std::min(const _Tp&, const _Tp&)'
min(const _Tp& __a, const _Tp& __b)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:195:5: note: template argument deduction/substitution failed:
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:1009:77: note: deduced conflicting types for parameter 'const _Tp' ('long unsigned int' and 'unsigned int')
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:243:5: note: candidate: 'template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)'
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algobase.h:243:5: note: template argument deduction/substitution failed:
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3450:5: note: candidate: 'template<class _Tp> _Tp std::min(std::initializer_list<_Tp>)'
min(initializer_list<_Tp> __l)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3450:5: note: template argument deduction/substitution failed:
.piolibdeps/esp32c3-remote/IRremoteESP8266/src/IRrecv.cpp:1009:77: note: mismatched types 'std::initializer_list<_Tp>' and 'long unsigned int'
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3456:5: note: candidate: 'template<class _Tp, class _Compare> _Tp std::min(std::initializer_list<_Tp>, _Compare)'
min(initializer_list<_Tp> __l, _Compare __comp)
/data/cache/platformio/packages/[email protected]+2021r2-patch5/riscv32-esp-elf/include/c++/8.4.0/bits/stl_algo.h:3456:5: note: template argument deduction/substitution failed:
*** [.pioenvs/esp32c3-remote/libbe5/IRremoteESP8266/IRrecv.cpp.o] Error 1
========================= [FAILED] Took 17.31 seconds =========================
esphome config
esphome:
friendly_name: esp32c3-remote
esp32:
board: esp32-c3-devkitm-1
framework:
type: arduino
wifi:
networks:
- ssid: !secret wifi_ssid
priority: 1
- ssid: !secret wifi2_ssid
password: !secret wifi2_password
priority: 2
output_power: 10dB
# use_address: 192.168.1.38
ota:
logger:
api:
web_server:
port: 80
status_led:
pin:
number: GPIO7
# inverted: False
button:
- platform: restart
# - platform: gpio
# pin: GPIO6
# name: Remote button
remote_receiver:
pin: GPIO3
dump: all
remote_transmitter:
pin: GPIO4
carrier_duty_percent: 50%
climate:
- platform: heatpumpir
protocol: mitsubishi_heavy_zm # adjust to match your AC unit!
name: "Living Room Air Con"
max_temperature: 28.0
min_temperature: 18.0
horizontal_default: auto
vertical_default: auto
# receiver_id: ir_receiver
# sensor: living_room_temperature
Any thoughts on this?
