stevemann
(Stephen Mann (YAML-challenged))
1
I am finally getting around to installing Bluetooth Proxy to an ESP32. I got this far in Settings/Integrations:
When I click on “CONTINUE”, I get this error:
## Error
Config flow could not be loaded: {"message":"Invalid flow specified"}
It appears that everyone who got this error in the past was installing HACS.
Any tips on how to proceed would be appreciated.
raidnet-ms
(Raidnet Ms)
2
Hi, I get the same error with IMPROV_BT on esp32dev board.
I have no HACS.
I can connect successfully the esp board to the wifi network with IMPROV_BT and later when I’m prompted to add the esp yaml I get this same error.
yakirg
3
I am getting the same error … No answer?
INFO ESPHome 2023.12.7
INFO Reading configuration /config/esphome/fridgetemp.yaml...
INFO Starting log output from 192.168.88.64 using esphome API
INFO Successfully connected to fridgetemp @ 192.168.88.64 in 0.003s
INFO Successful handshake with fridgetemp @ 192.168.88.64 in 2.633s
[19:10:02][I][app:102]: ESPHome version 2023.12.7 compiled on Jan 17 2024, 18:54:08
[19:10:02][C][wifi:573]: WiFi:
[19:10:02][C][wifi:405]: Local MAC: 18:FE:34:D9:09:06
[19:10:02][C][wifi:410]: SSID: [redacted]
[19:10:02][C][wifi:411]: IP Address: 192.168.88.64
[19:10:02][C][wifi:412]: BSSID: [redacted]
[19:10:02][C][wifi:414]: Hostname: 'fridgetemp'
[19:10:02][C][wifi:416]: Signal strength: -48 dB ▂▄▆█
[19:10:02][C][wifi:420]: Channel: 6
[19:10:02][C][wifi:421]: Subnet: 255.255.0.0
[19:10:02][C][wifi:422]: Gateway: 192.168.88.1
[19:10:02][C][wifi:423]: DNS1: 192.168.88.1
[19:10:02][C][wifi:424]: DNS2: 0.0.0.0
[19:10:02][C][logger:439]: Logger:
[19:10:02][C][logger:440]: Level: DEBUG
[19:10:02][C][logger:441]: Log Baud Rate: 115200
[19:10:02][C][logger:443]: Hardware UART: UART0
[19:10:02][C][dallas.sensor:075]: DallasComponent:
[19:10:02][C][dallas.sensor:076]: Pin: GPIO2
[19:10:02][C][dallas.sensor:077]: Update Interval: 60.0s
[19:10:02][D][dallas.sensor:082]: Found sensors:
[19:10:02][D][dallas.sensor:084]: 0x170722b215467c28
[19:10:02][D][dallas.sensor:084]: 0x230722b21928e328
[19:10:02][C][dallas.sensor:089]: Device 'Freezer Temperature'
[19:10:02][C][dallas.sensor:089]: Device Class: 'temperature'
[19:10:02][C][dallas.sensor:089]: State Class: 'measurement'
[19:10:02][C][dallas.sensor:089]: Unit of Measurement: '°C'
[19:10:02][C][dallas.sensor:089]: Accuracy Decimals: 1
[19:10:02][C][dallas.sensor:097]: Address: 0x170722b215467c28
[19:10:02][C][dallas.sensor:098]: Resolution: 12
[19:10:02][C][dallas.sensor:089]: Device 'Fridge Temperature'
[19:10:02][C][dallas.sensor:097]: Address: 0x230722b21928e328
[19:10:02][C][captive_portal:088]: Captive Portal:
[19:10:02][C][mdns:115]: mDNS:
[19:10:02][C][mdns:116]: Hostname: fridgetemp
[19:10:02][C][ota:097]: Over-The-Air Updates:
[19:10:02][C][ota:098]: Address: fridgetemp.local:8266
[19:10:02][C][ota:101]: Using Password.
[19:10:02][C][api:139]: API Server:
[19:10:02][C][api:140]: Address: fridgetemp.local:6053
[19:10:02][C][api:142]: Using noise encryption: YES
[19:10:12][D][dallas.sensor:143]: 'Freezer Temperature': Got Temperature=22.7°C
[19:10:12][D][sensor:093]: 'Freezer Temperature': Sending state 22.68750 °C with 1 decimals of accuracy
[19:10:12][D][dallas.sensor:143]: 'Fridge Temperature': Got Temperature=22.9°C
[19:10:12][D][sensor:093]: 'Fridge Temperature': Sending state 22.87500 °C with 1 decimals of accuracy
