HunZoo
(Hunzoo)
October 11, 2022, 11:03am
1
Hi guys,
I am new to the mqtt configuration and dont have much knowledge of dealing with json. I am trying to configure my tasmota flashed RF bridge with the door and motion sensors, however, when i add the config into the yaml file, im always getting this error:
Invalid config for [sensor]: required key not provided @ data[‘platform’]. Got None. (See /config/configuration.yaml, line 11).
I cannot figure out how to fix it. Here is what i have on my binary_sensors.yaml:
mqtt:
#Roof Door
- name: "Roof Door"
state_topic: "tele/bridge/RESULT"
value_template: '{{value_json.RfReceived.Data}}'
payload_available: "847BA9"
payload_off: "847BA9"
device_class: door
qos: 1
#PIR
- name: "Motion Stairs"
payload_on: "D238BE"
payload_off: "D238BE_off"
device_class: motion
off_delay: 5
qos: 1
Could someone please assist what might i be doing wrong here?
Yup.
Please post what version of Home Assistant you are actually running.
HunZoo
(Hunzoo)
October 11, 2022, 11:25am
3
Home Assistant 2022.10.0
Supervisor 2022.10.0
Operating System 9.0
Frontend 20221005.0 - latest
Thank you.
OK - if looks like your spacing is only one space and not two - so try this:
mqtt:
#Roof Door
- name: "Roof Door"
device_class: door
qos: 1
#PIR
off_delay: 5
qos: 1
HunZoo
(Hunzoo)
October 11, 2022, 11:30am
5
That didnt work, still giving me the same error when running check config
Please post all of your configuration.yaml so I can see what is actually happening before and after line 11.
Also hold on - the spacing is still wrong…
mqtt:
#Roof Door
- name: "Roof Door"
device_class: door
qos: 1
#PIR
off_delay: 5
qos: 1
The first sensor still had one too many spaces.
HunZoo
(Hunzoo)
October 11, 2022, 11:39am
8
I dont believe its a spacing problem, the file check is good, but the check config is the problem.
Here is the configuration.yaml, however, when i # all the lines in binary_sensors.yaml its fine, so it seems that the problem is within the binary_sensors.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
ssdp:
sun:
system_health:
config:
scene: !include scenes.yaml
group: !include groups.yaml
script: !include scripts.yaml
sensor: !include binary_sensors.yaml
switch: !include switch.yaml
#SSL setup
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
Also here is a sample of what im getting from the RF bridge:
11:58:11.504 MQT: tele/bridge/RESULT = {"Time":"2022-10-11T11:58:11","RfReceived":{"Sync":7520,"Low":260,"High":740,"Data":"51F333","RfKey":"None"}}
Right yes - so you are including the mqtt stuff INSIDE an included file?
HunZoo
(Hunzoo)
October 11, 2022, 11:42am
10
Yes, configuration.yaml just includes all other yaml files.
Is this not recommended?
That’s the problem, you can still have it in a separate file - and include that file, but you cannot do it the way you have - because:
what it actually says is:
binary_sensor:
mqtt:
which is clearly wrong.
You need to have your mqtt sensors in a new file, which you can then include with:
mqtt:
binary_sensor: !include mqtt-binary_sensors.yaml
You don’t include either mqtt or they type of the sensor in the included file obviously.
#Roof Door
- name: "Roof Door"
device_class: door
qos: 1
#PIR
off_delay: 5
qos: 1
HunZoo
(Hunzoo)
October 11, 2022, 11:53am
12
Excellent… Thank you so much i really need to understand my way around these yaml files
As an example - this is the core part of my config:
mqtt:
sensor: !include_dir_merge_list cfg/_component/mqtt/sensor/
binary_sensor: !include_dir_merge_list cfg/_component/mqtt/binary_sensor/
switch: !include_dir_merge_list cfg/_component/mqtt/switch/
sensor: !include_dir_merge_list cfg/_component/sensor/
binary_sensor: !include_dir_merge_list cfg/_component/binary_sensor/
climate: !include_dir_merge_list cfg/climate/
switch: !include_dir_merge_list cfg/_component/switch/
camera: !include_dir_merge_list cfg/_component/camera/
group: !include_dir_merge_named cfg/_component/group/
light: !include_dir_merge_list cfg/_component/light/
template: !include_dir_merge_list cfg/_component/template/
notify: !include notifiers.yaml
media_player: !include_dir_merge_list cfg/_component/media_player/
timer: !include_dir_merge_named cfg/_component/timer/
Because I have used !include_dir_merge_list
it means that I can have multiple files inside the folder for the respective integration - for example:
Inside cfg/_component/mqtt/sensor/ I have:
boiler_temperature.yaml
house_electric.yaml
ruuvi.yaml
temperature_foyer.yaml
temperature_organ_chamber.yaml
HunZoo
(Hunzoo)
October 11, 2022, 12:01pm
14
Thats a better way to have a clean folder structure.
Thanks for the tip
