ghizmo82
(Luigi Barbanelladocet Duchi)
October 8, 2019, 11:22pm
1
Hello i have installed home assistant on virtual Lenv over rpi 3b.
i have the last version (08/10/2019) 99.3
When i insert a cam onvif:
platform: onvif
host: 192.168.1.88
password: xxxxxx
port: 8000
i received this error on configuration check:
Platform error camera.onvif - Requirements for onvif not found: [‘onvif-zeep-async==0.2.0’].
i’ve try to install the dependencies but i received error
where is the problem? I’m becoming crazy
INSTAR
(Mike Polinowski)
October 12, 2019, 10:14am
2
+ 1
Same Problem here - after manual installation following this guide on Raspbian Buster / RasPi3
- platform: onvif
host: '192.168.2.165'
port: '8080'
username: 'admin'
password: 'instar'
Configuration invalid
Platform error camera.onvif - Requirements for onvif not found: ['onvif-zeep-async==0.2.0'].
Ok, I also did not set up FFMPEG now after adding the following lines (FFMPEG is installed)
ffmpeg:
ffmpeg_bin: /usr/bin/ffmpeg
It already fails there:
Component error: ffmpeg - Requirements for ffmpeg not found: ['ha-ffmpeg==2.0'].
Could that have something to do with the virtual environment home assistant is installed in?
ghizmo82
October 15, 2019, 6:46pm
3
yes,I think this is the problem, but I don’t understand how to solve it
piomark
(Piomark)
December 16, 2019, 8:35pm
4
Any luck with this one?
I’m facing the same problem:
camera - Requirements for onvif not found: [‘onvif-zeep-async==0.2.0’]
Sergeus
December 17, 2019, 9:23am
5
piomark:
onvif-zeep-async
sudo pip install onvif-zeep-async
piomark
(Piomark)
December 17, 2019, 8:38pm
6
Thank you for that, this led me to the compilation error
#include “libxml/xmlversion.h”
the header file is missing, gcc command
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -DCYTHON_CLINE_IN_TRACEBACK=0 -Isrc -Isrc/lxml/includes -I/srv/homeassistant/include -I/usr/local/include/python3.6m -c src/lxml/etree.c -o build/temp.linux-armv7l-3.6/src/lxml/etree.o -w
xmlversion.h is in /usr/include/libxml2/ I guess it should be specified in the gcc -I params?
Sergeus
December 24, 2019, 10:25am
7
sudo apt-get install libxml2-dev libxmlsec1-dev
