I have installed an ESP. I can access draf via the IP, I have installed ESPHome in HA and created the ESP ( ESP gas meter ).
esphome:
friendly_name: ESP-Gaszähler
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "/zrEQM4mfLb6PvYgH+UWw90x9u6Y0FeQ8Fb9r/Fh3l0="
ota:
- platform: esphome
password: "af5c7f9da95fec4c4e2c7b230dbfeef4"
wifi:
ssid: !secret wifi_ssid
domain: ".fritz.box"
manual_ip:
static_ip: 192.168.4.240
gateway: 192.168.4.1
dns1: 192.168.4.1
subnet: 255.255.255.0
ap:
ssid: "Esp-Gaszahler Fallback Hotspot"
password: "86WkaUdI1yhG"
captive_portal:
But when I run INSTALL I get the Errno 111 message
INFO ESPHome 2024.9.2
INFO Reading configuration /config/esphome/esp-gaszahler.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing esp-gaszahler (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.6
RAM: [==== ] 41.7% (used 34176 bytes from 81920 bytes)
Flash: [===== ] 47.6% (used 487605 bytes from 1023984 bytes)
========================= [SUCCESS] Took 11.14 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.4.240
ERROR Connecting to 192.168.4.240:8266 failed: [Errno 111] Connection refused
Do I still have to set up port forwarding in the router to port 8266?
Gruß
Andreas
