Hi all,
Having some hassle setting up my router at the mo.
Home Assistant: 0.30.2
DD-WRT v3.0-r30700M kongac Release: 09/27/16
I have HA installed on Ubuntu 16.04 on an Intel NUC. It is wired back to my switch, which is in turn wired to the router. Dumb question time, will HA try use the wireless interface (disabled) on the NUC rather than the wired?
SSH is enabled on the router, telnet disabled. I have the id_rsa.pub from the NUC on the router and the username and password work via the web gui for the router.
My config in configuration.yml is as follows:
device_tracker:
- platform: ddwrt
host: 192.168.xx.xx
username: user
password: pass
track_new_devices: yes
interval_seconds: 10
consider_home: 180
Log file as follows:
16-10-13 22:10:13 homeassistant.components.device_tracker: Error setting up platform ddwrt
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connection.py", line 142, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/util/connection.py", line 98, in create_connection
raise err
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/util/connection.py", line 88, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connectionpool.py", line 595, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connectionpool.py", line 363, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/lib/python3.5/http/client.py", line 1106, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1151, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1102, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connection.py", line 167, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connection.py", line 151, in _new_conn
self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.HTTPConnection object at 0x7f16a808b048>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/connectionpool.py", line 640, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.5/dist-packages/requests/packages/urllib3/util/retry.py", line 287, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
requests.packages.urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.33.1', port=80): Max retries exceeded with url: /Status_Wireless.live.asp (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7f16a808b048>: Failed to establish a new connection: [Errno 111] Connection refused',))
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/device_tracker/__init__.py", line 139, in setup_platform
scanner = platform.get_scanner(hass, {DOMAIN: p_config})
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/device_tracker/ddwrt.py", line 38, in get_scanner
scanner = DdWrtDeviceScanner(config[DOMAIN])
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/device_tracker/ddwrt.py", line 61, in __init__
data = self.get_ddwrt_data(url)
File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/device_tracker/ddwrt.py", line 146, in get_ddwrt_data
timeout=4)
File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 70, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/api.py", line 56, in requestPreformatted text
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 475, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/sessions.py", line 596, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/requests/adapters.py", line 487, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.33.1', port=80): Max retries exceeded with url: /Status_Wireless.live.asp (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x7f16a808b048>: Failed to establish a new connection: [Errno 111] Connection refused',))
Any assistance appreciated!
Ronan
