I have moved my installation to a new PI raspberry 4 .
This installation uses an external database Maria DB.
After a reboot of raspberry I am getting an error in the log file
Thu Dec 05 2019 12:38:49 GMT+0200 (GMT+02:00)
Error during connection setup: (MySQLdb._exceptions.OperationalError) (2002, “Can’t connect to MySQL server on ‘192.168.10.105’ (101)”) (Background on this error at: http://sqlalche.me/e/e3q8) (retrying in 3 seconds)
Then, it connects successfully. This only happens after I reboot raspberry but not when I restart only home assistant.
The mysql Server is on the same machine as the HA installation? Then the mysql server is not fully loaded, when HA tries to establish a connection. Nothing to worry about, HA should try it a few seconds later, and if the server is running, it will automatically connect.
Edit: if you restart HA, you only start the docker container again, not the PI. That’s why your mysql server is not affected by a HA restart.
The mysql server is on a NAS which is on a different machine. It is always running since there are other databases running. My installation is in a virtual environment not in a docker(can be seen in my initial post)
My service that starts home assistant
Description=Home Assistant
After=network-online.target [email protected]
Just want to let you know that with the same setup on my previous raspberry I was not facing any issue with the auto start of the Home Assistant.
The only difference was the hardware old pi raspberry and the python version was 3.6.5
