We are trying to get a trigger to run a web request and it keeps erroring out. We are at a loss as to what could be causing it and not sure if we are setting up the code correctly. The URL does work when using a get webhook in IFTT so we know the url is correct but not sure why it doesn’t work through home assistant.
In configuration.yaml we have tried:
rest_command:
orange_request:
url: "http://myurl:5000/orange"
method: get
and in the automation we have put but it errors out when triggering. We are not really even sure if rest command is the right command? Please help!
