Error creating automation with nested IF actions
I have an automation that is intended to set the color of a scene controller button LED based on values of other switches.
I originally had it “mostly” working with just a series of if-thens for the actions using this config.
alias: Set Kitchen Zooz Scene 2 LED Color
description: ""
  - platform: event
    event_type: set_zooz_scene2_color
condition: []
  - if:
      - condition: state
        entity_id: switch.second_floor_lights
        state: "on"
    then:
      - device_id: 5416582252fbb94e976a1524c3ea804e
        domain: zwave_js
        type: set_config_parameter
        parameter: 8
        bitmask: null
        subtype: 8 (LED Indicator Color (Button 2))
        value: 3
  - if:
      - condition: state
        entity_id: switch.first_floor_lights
        state: "on"
    then:
        domain: zwave_js
        parameter: 8
        bitmask: null
        value: 2
  - if:
      - condition: state
        entity_id: switch.basement_lights
        state: "on"
    then:
        domain: zwave_js
        parameter: 8
        bitmask: null
        value: 1
mode: single
But this did not handle the condition if ALL of the switches are off. So I tried to nest these if-thens into another if-then which first checks if any of then are on, and then sets the color base don the floor, else (none of then are “on”) set the color to white.
description: ""
  - platform: event
condition: []
  - if:
      - condition: or
        conditions:
          - condition: state
            state: "on"
          - condition: state
            state: "on"
          - condition: state
            state: "on"
    then:
      - if:
          - condition: state
            state: "on"
        then:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 1
      - if:
          - condition: state
            state: "on"
        then:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 2
      - if:
          - condition: state
            state: "on"
        then:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 3
    else:
        domain: zwave_js
        parameter: 8
        bitmask: null
mode: single
However, I am getting the following error trying to save this automation.
Message malformed: not a valid value for dictionary value @ data[‘type’]
If I am going about this all wrong (very likely), by all means please advise. But I would still like to understand this error message a little better, regardless.
Don’t nest If/Then actions, use the Choose action with a default action to handle when all switches are off.
  - choose:
    - conditions:
        - condition: state
          state: "on"
      sequence:
          domain: zwave_js
          parameter: 8
          bitmask: null
          value: 3
    - conditions:
        - condition: state
          state: "on"
      sequence:
          domain: zwave_js
          parameter: 8
          bitmask: null
          value: 2
    - conditions:
        - condition: state
          state: "on"
      sequence:
          domain: zwave_js
          parameter: 8
          bitmask: null
          value: 1
    default:
        domain: zwave_js
        parameter: 8
        bitmask: null
mode: single
Thank you. I tried that and got the same error. However, I believe I found the issue.
The “default” action I was going for (either with the “nested if” or the “choose”) was to set the LED color to white (value: 0), which is the default setting for that parameter. I was doing all of this in the WebUI rather than editing the YAML directly; and for some reason the WebUI was not setting a “value” if I set the color to white. I believe this is because white is the default (0) value.
Anyway, by manually adding a “value: 0” to the default action I was able to get it to accept the config; either with a nested if or with a choose.
So my final YAML using the Choose option looks like this:
description: ""
  - platform: event
condition: []
  - choose:
      - conditions:
          - condition: state
            state: "on"
        sequence:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 1
      - conditions:
          - condition: state
            state: "on"
        sequence:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 2
      - conditions:
          - condition: state
            state: "on"
        sequence:
            domain: zwave_js
            parameter: 8
            bitmask: null
            value: 3
    default:
        domain: zwave_js
        parameter: 8
        bitmask: null
        value: 0  //     <<<<<<<-------------  I had to add this line
mode: single
