I try to install Home Assistant on a Raspberry as described on:
https://www.home-assistant.io/installation/raspberrypi/#install-home-assistant-container
I use the following command:
docker run -d \
--name homeassistant \
--privileged \
--restart=unless-stopped \
-e TZ=Europe/Berlin \
-v /home/pi/homeassistant_config:/config \
--network=raspi \
ghcr.io/home-assistant/home-assistant:stable
But I get the following error:
docker: Error response from daemon: network raspi not found.
Same when I use the IP address directly:
docker run -d \
--privileged \
--network=192.168.188.xxx \
