ERROR: does not contain a dictionary
I have recently reconfigured my raspberry pi 3, with python 3.7.3. I recompiled my configuration.yaml file with all the devices I had. When I verify the configuration, Home Assistant (Ver. 0.95.0) gives me this error:
Error loading /home/homeassistant/.homeassistant/configuration.yaml: The configuration file configuration.yaml does not contain a dictionary
What is missing from my configuration?
Post your correctly formatted config or it’s difficult to help.
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  • http:
    base_url: xxxxxxxxxxxxxxxxxxxx:xxxx
  • mqtt:
    broker: 127.0.0.1
    port: xxxx
    client_id: xxxxxxxxxxxxxxxxxxxx
    keepalive: 60
    discovery: false
    discovery_prefix: xxxxxxxxxxxxxxxxxxxx
Sensors
  • sensor:
- Weather prediction
  • platform: yr
######### Configurazione Sonoff TH16 Rel ##########
Balcone Sala
  • platform: mqtt
    name: “Luce Balcone Sala”
    unique_id: “01”
    command_topic: “cmnd/SONOFF_TH_FIN_SALA/POWER”
    state_topic: “stat/SONOFF_TH_FIN_SALA/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Balcone Cucina
  • platform: mqtt
    name: “Luce Balcone Cucina”
    unique_id: “02”
    command_topic: “cmnd/SONOFF_TH_FIN_CUCINA/POWER”
    state_topic: “stat/SONOFF_TH_FIN_CUCINA/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Balcone Cameretta
  • platform: mqtt
    name: “Luce Balcone Cameretta”
    unique_id: “03”
    command_topic: “cmnd/SONOFF_TH_FIN_CAMERETTA/POWER”
    state_topic: “stat/SONOFF_TH_FIN_CAMERETTA/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Balcone Camera
  • platform: mqtt
    name: “Luce Balcone Camera”
    unique_id: “04”
    command_topic: “cmnd/SONOFF_TH_FIN_CAMERA/POWER”
    state_topic: “stat/SONOFF_TH_FIN_CAMERA/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Comando Caldaia Termosifoni
  • platform: mqtt
    name: “Comando Termosifoni”
    unique_id: “05”
    command_topic: “cmnd/SONOFF_TH_FIN_CALDAIA/POWER”
    state_topic: “stat/SONOFF_TH_FIN_CALDAIA/POWER”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
########## Configurazione Sonoff Dual R2 ###########
Serranda Sala - Apre
  • platform: mqtt
    name: “Apri Serranda Sala”
    unique_id: “06”
    command_topic: “cmnd/SONOFF_SER_SALA/POWER1”
    state_topic: “stat/SONOFF_SER_SALA/POWER1”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Serranda Sala - Chiude
  • platform: mqtt
    name: “Chiudi Serranda Sala”
    unique_id: “07”
    command_topic: “cmnd/SONOFF_SER_SALA/POWER2”
    state_topic: “stat/SONOFF_SER_SALA/POWER2”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Serranda Cucina - Apre
  • platform: mqtt
    name: “Apri Serranda Cucina”
    unique_id: “08”
    command_topic: “cmnd/SONOFF_SER_CUCINA/POWER1”
    state_topic: “stat/SONOFF_SER_CUCINA/POWER1”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Serranda Cucina - Chiude
  • platform: mqtt
    name: “Chiudi Serranda Cucina”
    unique_id: “09”
    command_topic: “cmnd/SONOFF_SER_CUCINA/POWER2”
    state_topic: “stat/SONOFF_SER_CUCINA/POWER2”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Configurazione Sonoff Ch4 Pro R2 CAMERETTA
CH1 - Apri Serranda DX Cameretta
  • platform: mqtt
    name: “Apri Serranda DX Cameretta”
    unique_id: “10”
    command_topic: “cmnd/SONOFF_SER_CAMERETTA/POWER1”
    state_topic: “stat/SONOFF_SER_CAMERETTA/POWER1”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH2 - Chiudi Serranda DX Cameretta
  • platform: mqtt
    name: “Chiudi Serranda DX Cameretta”
    unique_id: “11”
    command_topic: “cmnd/SONOFF_SER_CAMERETTA/POWER2”
    state_topic: “stat/SONOFF_SER_CAMERETTA/POWER2”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH3 - Apre Serranda SX Cameretta
  • platform: mqtt
    name: “Apri Serranda SX Cameretta”
    unique_id: “12”
    command_topic: “cmnd/SONOFF_SER_CAMERETTA/POWER3”
    state_topic: “stat/SONOFF_SER_CAMERETTA/POWER3”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH4 - Chiude Serranda SX Cameretta
  • platform: mqtt
    name: “Chiudi Serranda SX Cameretta”
    unique_id: “13”
    command_topic: “cmnd/SONOFF_SER_CAMERETTA/POWER4”
    state_topic: “stat/SONOFF_SER_CAMERETTA/POWER4”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
Configurazione Sonoff Ch4 Pro R2 CAMERA da LETTO
CH1 - Apre Serranda DX Camera
  • platform: mqtt
    name: “Apri Serranda DX Camera”
    unique_id: “14”
    command_topic: “cmnd/SONOFF_SER_CAMERA/POWER1”
    state_topic: “stat/SONOFF_SER_CAMERA/POWER1”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH2 - Chiude Serranda DX Camera
  • platform: mqtt
    name: “Chiudi Serranda DX Camera”
    unique_id: “15”
    command_topic: “cmnd/SONOFF_SER_CAMERA/POWER2”
    state_topic: “stat/SONOFF_SER_CAMERA/POWER2”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH3 - Apre Serranda SX Camera
  • platform: mqtt
    name: “Apri Serranda SX Camera”
    unique_id: “16”
    command_topic: “cmnd/SONOFF_SER_CAMERA/POWER3”
    state_topic: “stat/SONOFF_SER_CAMERA/POWER3”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
CH4 - Chiude Serranda SX Camera
  • platform: mqtt
    name: “Chiudi Serranda SX Camera”
    unique_id: “17”
    command_topic: “cmnd/SONOFF_SER_CAMERA/POWER4”
    state_topic: “stat/SONOFF_SER_CAMERA/POWER4”
    qos: 1
    payload_on: “ON”
    payload_off: “OFF”
    retain: true
################# Sonoff POR R2 #######################
  • platform: mqtt
    name: “Data aggiornamento”
    state_topic: “tele/SONOFF_POW/SENSOR”
    value_template: “{{value_json[‘ENERGY’].TotalStartTime }}”
    qos: 1
    unit_of_measurement : “Date”
  • platform: mqtt
    value_template: “{{value_json[‘ENERGY’].Total }}”
    qos: 1
    unit_of_measurement : “kWh”
  • platform: mqtt
    value_template: “{{value_json[‘ENERGY’].Yesterday }}”
    qos: 1
  • platform: mqtt
    value_template: “{{value_json[‘ENERGY’].Today }}”
    unit_of_measurement: “kWh”
  • platform: mqtt
    name: “Assorbimento da ultima lettura”
    value_template: “{{value_json[‘ENERGY’].Period }}”
  • platform: mqtt
    name: “Assorbimento istantaneo”
    value_template: “{{value_json[‘ENERGY’].Power }}”
    unit_of_measurement: “Watt”
  • platform: mqtt
    state_topic: “tele/SONOF_POW/SENSOR”
    value_template: “{{value_json[‘ENERGY’].ApparentPower }}”
  • platform: mqtt
    name: “Voltampere reattivo”
    value_template: “{{value_json[‘ENERGY’].ReactivePower }}”
  • platform: mqtt
    value_template: “{{value_json[‘ENERGY’].Voltage }}”
    unit_of_measurement: “Volt”
  • platform: mqtt
    value_template: “{{value_json[‘ENERGY’].Current }}”
    unit_of_measurement: “Ampere”
############## Sonoff Sensori Temperatura e Umidità ##############
  • platform: mqtt
    name: “Temperatura Sala da Pranzo”
    unique_id: “20”
    state_topic: “tele/SONOFF_TH_FIN_SALA/SENSOR”
    unit_of_measurement: ‘°C’
    value_template: “{{ value_json.SI7021.Temperature }}”
  • platform: mqtt
    name: “Umidita Sala da Pranzo”
    unique_id: “21”
    unit_of_measurement: ‘%’
    value_template: “{{ value_json.SI7021.Humidity }}”
  • platform: mqtt
    unique_id: “22”
    state_topic: “tele/SONOFF_TH_FIN_CUCINA/SENSOR”
  • platform: mqtt
    unique_id: “23”
  • platform: mqtt
    name: “Temperatura Cameretta”
    unique_id: “24”
    state_topic: “tele/SONOFF_TH_FIN_CAMERETTA/SENSOR”
  • platform: mqtt
    name: “Umidita Cameretta”
    unique_id: “25”
  • platform: mqtt
    unique_id: “26”
    state_topic: “tele/SONOFF_TH_FIN_CAMERA/SENSOR”
  • platform: mqtt
    unique_id: “27”
  • platform: mqtt
    unique_id: “28”
    state_topic: “tele/SONOFF_TH_FIN_CALDAIA/SENSOR”
  • platform: mqtt
    unique_id: “29”
########## Luci LED Armadio Cameretta #########
  • platform: flux_led
    automatic_add: true
    devices: 192.168.10.51
    name: Luce Armadio Cameretta
  • type: history-graph
    title: Temperatura 24H
    entities:
    • sensor.temperatura_esterna
    • sensor.temperatura_sala_da_pranzo
    • sensor.temperatura_cucina
    • sensor.temperatura_cameretta
    • sensor.temperatura_camera
      hours_to_show: 24
      refresh: 20
    title: umidita 24H
    entities:
    • sensor.umidita_esterna
    • sensor.umidita_sala_da_pranzo
    • sensor.umidita_cucina
    • sensor.umidita_cameretta
    • sensor.umidita_camera
      hours_to_show: 24
      refresh: 20
    title: Temperatura Ultima Settimana
    entities:
      hours_to_show: 168
      refresh: 20
    title: umidita Ultima Settimana
    entities:
      hours_to_show: 168
      refresh: 20
    title: Temperatura Ultimo Mese
    entities:
      hours_to_show: 720
      refresh: 20
    title: umidita Ultimo Mese
    entities:
      hours_to_show: 720
      refresh: 20
    title: Temperatura Ultimo Anno
    entities:
      hours_to_show: 8760
      refresh: 20
    title: umidita Ultimo Anno
    entities:
      hours_to_show: 8760
      refresh: 20
Tasmota
  • entity: sensor.tasmota_current_version
    name: Tasmota Current Version
    icon: mdi:alpha-s-box-outline
  • entity: sensor.tasmota_earliest_installed_version
    name: Tasmota Earliest Installed Version
########## Configurazione Sensori Rasbyan ##########
  • platform: systemmonitor
    resources:
  • type: disk_use_percent
    arg: /home
  • type: memory_free
    arg: ./home
  • type: disk_use
    arg: /home
  • type: disk_free
    arg: /home
  • type: memory_use_percent
  • type: memory_use
  • type: memory_free
  • type: swap_use_percent
  • type: swap_use
  • type: swap_free
  • type: load_1m
  • type: load_5m
  • type: load_15m
  • type: network_in
  • arg: eth0
  • type: network_out
    arg: eth0
  • type: packets_in
    arg: eth0
  • type: packets_out
    arg: eth0
  • type: ipv4_address
    arg: eth0
  • type: processor_use
  • type: process
    arg: octave-cli
  • type: last_boot
Sensori Raspberry
Ultimo Riavvio
  • platform: uptime
    unit_of_measurement: hours
Termometro Processore Raspberry
  • platform: command_line
    name: CPU Temperature
    friendly_name: ‘CPU’
    command: “cat /sys/class/thermal/thermal_zone0/temp”
    unit_of_measurement: “°C”
    scan_interval: 120
    value_template: ‘{{ value | multiply(0.001) }}’
Ultima versione di HA disponibile
Versione di HA installata
    name: Versione HA Installata
    command: “head -5 /home/homeassistant/.homeassistant/.HA_VERSION”
    scan_interval: 21600 # ogni 6 ore
########## Servizio Meteo ##########
  • platform: yweather
    forecast: 1
    monitored_conditions:
    • weather
    • weather_current
    • temp_min
    • temp_max
    • wind_speed
    • pressure
    • visibility
    • humidity
    • temperature
    forecast: 2
    • weather
    • weather_current
    • temp_min
    • temp_max
    • wind_speed
    • pressure
    • visibility
    • humidity
    • temperature
Ora e Data
  • platform: worldclock
    time_zone: Europe/Rome
  • platform: time_date
    display_options:
    • ‘time’
    • ‘date’
    • ‘time_utc’
######## BROCHER MQTT ########
  • mqtt:
    broker: xxx.xxx.xxx.xxx
######### File di Configrazione ###########
#automation: !include automations.yaml
#group: !include groups.yaml
#script: !include scripts.yaml
#graph: !include graph.yaml
#device: !include device.yaml
Thank you in advance.
I hope I copied well …
You copied the configuration well but the result is not formatted (making it difficult to read and check for any errors).
To format it, edit your post and add three back-quotes ``` on a separate line before the entire configuration. Then go to the end of the configuration and add another three back-quotes on a separate line. Save the post and now the configuration will appear formatted.
# Configure a default setup of Home Assistant (frontend, api, etc)
#  default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  - http:
  - mqtt:
    broker: 127.0.0.1
    port: xxxx
    keepalive: 60
    discovery: false
# Sensors
  - sensor:
#  - Weather prediction
  - platform: yr
### Balcone Sala
  - platform: mqtt
    name: "Luce Balcone Sala"
    unique_id: "01"
    command_topic: "cmnd/SONOFF_TH_FIN_SALA/POWER"
    state_topic: "stat/SONOFF_TH_FIN_SALA/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Balcone Cucina
  - platform: mqtt
    name: "Luce Balcone Cucina"
    unique_id: "02"
    command_topic: "cmnd/SONOFF_TH_FIN_CUCINA/POWER"
    state_topic: "stat/SONOFF_TH_FIN_CUCINA/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Balcone Cameretta
  - platform: mqtt
    name: "Luce Balcone Cameretta"
    unique_id: "03"
    command_topic: "cmnd/SONOFF_TH_FIN_CAMERETTA/POWER"
    state_topic: "stat/SONOFF_TH_FIN_CAMERETTA/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Balcone Camera
  - platform: mqtt
    name: "Luce Balcone Camera"
    unique_id: "04"
    command_topic: "cmnd/SONOFF_TH_FIN_CAMERA/POWER"
    state_topic: "stat/SONOFF_TH_FIN_CAMERA/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Comando Caldaia Termosifoni
  - platform: mqtt
    name: "Comando Termosifoni"
    unique_id: "05"
    command_topic: "cmnd/SONOFF_TH_FIN_CALDAIA/POWER"
    state_topic: "stat/SONOFF_TH_FIN_CALDAIA/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Serranda Sala - Apre
  - platform: mqtt
    name: "Apri Serranda Sala"
    unique_id: "06"
    command_topic: "cmnd/SONOFF_SER_SALA/POWER1"
    state_topic: "stat/SONOFF_SER_SALA/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Serranda Sala - Chiude
  - platform: mqtt
    name: "Chiudi Serranda Sala"
    unique_id: "07"
    command_topic: "cmnd/SONOFF_SER_SALA/POWER2"
    state_topic: "stat/SONOFF_SER_SALA/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Serranda Cucina - Apre
  - platform: mqtt
    name: "Apri Serranda Cucina"
    unique_id: "08"
    command_topic: "cmnd/SONOFF_SER_CUCINA/POWER1"
    state_topic: "stat/SONOFF_SER_CUCINA/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### Serranda Cucina - Chiude
  - platform: mqtt
    name: "Chiudi Serranda Cucina"
    unique_id: "09"
    command_topic: "cmnd/SONOFF_SER_CUCINA/POWER2"
    state_topic: "stat/SONOFF_SER_CUCINA/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
##### Configurazione Sonoff Ch4 Pro R2 CAMERETTA #######
### CH1 - Apri Serranda DX Cameretta
  - platform: mqtt
    name: "Apri Serranda DX Cameretta"
    unique_id: "10"
    command_topic: "cmnd/SONOFF_SER_CAMERETTA/POWER1"
    state_topic: "stat/SONOFF_SER_CAMERETTA/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH2 - Chiudi Serranda DX Cameretta
  - platform: mqtt
    name: "Chiudi Serranda DX Cameretta"
    unique_id: "11"
    command_topic: "cmnd/SONOFF_SER_CAMERETTA/POWER2"
    state_topic: "stat/SONOFF_SER_CAMERETTA/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH3 - Apre Serranda SX Cameretta
  - platform: mqtt
    name: "Apri Serranda SX Cameretta"
    unique_id: "12"
    command_topic: "cmnd/SONOFF_SER_CAMERETTA/POWER3"
    state_topic: "stat/SONOFF_SER_CAMERETTA/POWER3"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH4 - Chiude Serranda SX Cameretta
  - platform: mqtt
    name: "Chiudi Serranda SX Cameretta"
    unique_id: "13"
    command_topic: "cmnd/SONOFF_SER_CAMERETTA/POWER4"
    state_topic: "stat/SONOFF_SER_CAMERETTA/POWER4"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
##### Configurazione Sonoff Ch4 Pro R2 CAMERA da LETTO #####
### CH1 - Apre Serranda DX Camera
  - platform: mqtt
    name: "Apri Serranda DX Camera"
    unique_id: "14"
    command_topic: "cmnd/SONOFF_SER_CAMERA/POWER1"
    state_topic: "stat/SONOFF_SER_CAMERA/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH2 -  Chiude Serranda DX Camera
  - platform: mqtt
    name: "Chiudi Serranda DX Camera"
    unique_id: "15"
    command_topic: "cmnd/SONOFF_SER_CAMERA/POWER2"
    state_topic: "stat/SONOFF_SER_CAMERA/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH3 - Apre Serranda SX Camera
  - platform: mqtt
    name: "Apri Serranda SX Camera"
    unique_id: "16"
    command_topic: "cmnd/SONOFF_SER_CAMERA/POWER3"
    state_topic: "stat/SONOFF_SER_CAMERA/POWER3"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
### CH4 - Chiude Serranda SX Camera
  - platform: mqtt
    name: "Chiudi Serranda SX Camera"
    unique_id: "17"
    command_topic: "cmnd/SONOFF_SER_CAMERA/POWER4"
    state_topic: "stat/SONOFF_SER_CAMERA/POWER4"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: true
  - platform: mqtt
    name: "Data aggiornamento"
    state_topic: "tele/SONOFF_POW/SENSOR"
    value_template: "{{value_json['ENERGY'].TotalStartTime }}"
    qos: 1
    unit_of_measurement : "Date"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Total }}"
    qos: 1
    unit_of_measurement : "kWh"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Yesterday }}"
    qos: 1
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Today }}"
    unit_of_measurement: "kWh"
  - platform: mqtt
    name: "Assorbimento da ultima lettura"
    value_template: "{{value_json['ENERGY'].Period }}"
  - platform: mqtt
    name: "Assorbimento istantaneo"
    value_template: "{{value_json['ENERGY'].Power }}"
    unit_of_measurement: "Watt"
  - platform: mqtt
    state_topic: "tele/SONOF_POW/SENSOR"
    value_template: "{{value_json['ENERGY'].ApparentPower }}"
  - platform: mqtt
    name: "Voltampere reattivo"
    value_template: "{{value_json['ENERGY'].ReactivePower }}"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Voltage }}"
    unit_of_measurement: "Volt"
  - platform: mqtt
    value_template: "{{value_json['ENERGY'].Current }}"
    unit_of_measurement: "Ampere"
  - platform: mqtt
    name: "Temperatura Sala da Pranzo"
    unique_id: "20"
    state_topic: "tele/SONOFF_TH_FIN_SALA/SENSOR"
    unit_of_measurement: '°C'
    value_template: "{{ value_json.SI7021.Temperature }}"
  - platform: mqtt
    name: "Umidita Sala da Pranzo"
    unique_id: "21"
    unit_of_measurement: '%'
    value_template: "{{ value_json.SI7021.Humidity }}"
  - platform: mqtt
    unique_id: "22"
    state_topic: "tele/SONOFF_TH_FIN_CUCINA/SENSOR"
  - platform: mqtt
    unique_id: "23"
  - platform: mqtt
    name: "Temperatura Cameretta"
    unique_id: "24"
    state_topic: "tele/SONOFF_TH_FIN_CAMERETTA/SENSOR"
  - platform: mqtt
    name: "Umidita Cameretta"
    unique_id: "25"
  - platform: mqtt
    unique_id: "26"
    state_topic: "tele/SONOFF_TH_FIN_CAMERA/SENSOR"
  - platform: mqtt
    unique_id: "27"
  - platform: mqtt
    unique_id: "28"
    state_topic: "tele/SONOFF_TH_FIN_CALDAIA/SENSOR"
  - platform: mqtt
    unique_id: "29"
  - platform: flux_led
    automatic_add: true
  - type: history-graph
    entities:
      - sensor.temperatura_esterna
      - sensor.temperatura_sala_da_pranzo
      - sensor.temperatura_cucina
      - sensor.temperatura_cameretta
      - sensor.temperatura_camera
    hours_to_show: 24
    refresh: 20
    title: umidita 24H
    entities:
      - sensor.umidita_esterna
      - sensor.umidita_sala_da_pranzo
      - sensor.umidita_cucina
      - sensor.umidita_cameretta
      - sensor.umidita_camera
    hours_to_show: 24
    refresh: 20
    entities:
    hours_to_show: 168
    refresh: 20
    entities:
    hours_to_show: 168
    refresh: 20
    entities:
    hours_to_show: 720
    refresh: 20
    entities:
    hours_to_show: 720
    refresh: 20
    entities:
    hours_to_show: 8760
    refresh: 20
    entities:
    hours_to_show: 8760
    refresh: 20
##### Tasmota #####
  - entity: sensor.tasmota_current_version
  - entity: sensor.tasmota_earliest_installed_version
# sensor:
  - platform: systemmonitor
    resources:
  - type: disk_use_percent
    arg: /home
  - type: memory_free
    arg: ./home
  - type: disk_use
    arg: /home
  - type: disk_free
    arg: /home
  - type: memory_use_percent
  - type: memory_use
  - type: memory_free
  - type: swap_use_percent
  - type: swap_use
  - type: swap_free
  - type: load_1m
  - type: load_5m
  - type: load_15m
  - type: network_in
  - arg: eth0
  - type: network_out
    arg: eth0
  - type: packets_in
    arg: eth0
  - type: packets_out
    arg: eth0
  - type: ipv4_address
    arg: eth0
  - type: processor_use
  - type: process
    arg: octave-cli
  - type: last_boot
##### Sensori Raspberry #####
# Ultimo Riavvio
  - platform: uptime
# Termometro Processore Raspberry
  - platform: command_line
    friendly_name: 'CPU'
    command: "cat /sys/class/thermal/thermal_zone0/temp"
    unit_of_measurement: "°C"
    scan_interval: 120
    value_template: '{{ value | multiply(0.001) }}'
# Ultima versione di HA disponibile
  - platform: rest
    name: Versione HA Corrente
    resource: https://pypi.python.org/pypi/homeassistant/json
    value_template: '{{ value_json.info.version }}'
# Versione di HA installata ######
    command: "head -5 /home/homeassistant/.homeassistant/.HA_VERSION"
  - platform: yweather
    forecast: 1
      - weather
      - weather_current
      - temp_min
      - temp_max
      - wind_speed
      - pressure
      - visibility
      - humidity
      - temperature
    forecast: 2
      - weather
      - weather_current
      - temp_min
      - temp_max
      - wind_speed
      - pressure
      - visibility
      - humidity
      - temperature
###### Ora e Data ######
  - platform: worldclock
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'time_utc'
  -  mqtt:
should be OK.
however I found the problem …
when I insert the graphs, the value in the “entities:” field is missing.
then the line with “title: xxxxxxx” should be formatted like this “- title: xxxxxxx”
Many thanks to everyone for their interest.
I’ve never used History-Graph but the way it is shown in your configuration doesn’t look anything like it is described in the documentation’s example:
https://www.home-assistant.io/components/history_graph/#full-example
And in reality that entire confguration.yaml file looks completely screwed up.
It has elements of a regular configuration.yaml file but all of the top level keys are entered as list entries. The sensor section has the indentations screwed up and the Sonoff switches are listed under the (screwed up) sensor section. And there is no “switch:” entry to define the sonoff switches that are listed. And i may be mistaked isn’t the flux_led a light component? Where is the “light:” key that defines it that way?
And the history-graphs are lovelace cards so I’m not even sure why they are in that file.
And every history-graph card after the first one is missing the “-type: history-graph”
I could be wrong but I don’t see how the OP says that it “should be OK”. As far as I can tell there’s no way that it will work with what was posted as the “configuration.yaml” file.
I get the feeling it’s an amalgamation of several files, just for posting purposes.
Otherwise, I agree because, for example, the domain sections are commented out (# sensors:) which produces a config file that wouldn’t pass Config Check.
Well, if that’s the case then that sucks too.
It’s hard to help someone when you ask for them to post a specific thing and then they do something else entirely.
