Hi there,
I’m getting the following error with every startup of Home Assistant.
Looks like it has something to do with the Airzone component. However, I have not configured any Airzone devices. Is there a configuration I can use to disable the Airzone component as it is not needed in my setup?
Logger: homeassistant
Quelle: components/airzone/config_flow.py:113
Erstmals aufgetreten: 13:13:32 (1 Vorkommnisse)
Zuletzt protokolliert: 13:13:32
Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/discovery_flow.py", line 104, in _async_start
await gather_with_limited_concurrency(FLOW_INIT_LIMIT, *init_coros)
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 218, in gather_with_limited_concurrency
return await gather(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 216, in sem_task
return await task
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1050, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1080, in _async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 502, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/airzone/config_flow.py", line 113, in async_step_dhcp
await airzone.get_version()
File "/usr/local/lib/python3.12/site-packages/aioairzone/localapi.py", line 502, in get_version
res = await self.http_request(
File "/usr/local/lib/python3.12/site-packages/aioairzone/localapi.py", line 167, in http_request
resp: ClientResponse = await self.aiohttp_session.request(
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 504, in _request
with timer:
File "/usr/local/lib/python3.12/site-packages/aiohttp/helpers.py", line 735, in __exit__
raise asyncio.TimeoutError from None
TimeoutError
