Hey, I would like to override my ESP and get follow error
Serial port /dev/ttyUSB0
Connecting......................................
ERROR Running command failed: Failed to connect to ESP32: Download mode successfully detected, but getting no sync reply: The serial TX path seems to be down.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 460800 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/xxx/.pioenvs/xxx/firmware.bin 0x1000 /data/xxx/.pioenvs/xxx/bootloader.bin 0x8000 /data/xxx/.pioenvs/xxx/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
INFO Upload with baud rate 460800 failed. Trying again with baud rate 115200.
esptool.py v4.6
ERROR Please try running esptool.py --before default_reset --after hard_reset --baud 115200 --port /dev/ttyUSB0 --chip esp32 write_flash -z --flash_size detect 0x10000 /data/xxx.pioenvs/xxx/firmware.bin 0x1000 /data/xxx/.pioenvs/xxx/bootloader.bin 0x8000 /data/xxx/.pioenvs/xxx/partitions.bin 0xe000 /data/cache/platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin locally.
What should I do?
