Hello everyone, I’m really stuck and that’s why I signed up here. I hope someone can help me. I’ve installed Home Assistant on a NUC (OS Version 10.5 - HA Core 2023.8.4), it seems to have worked as I can control my blinds through HA, for example. However, I can’t install HACS. I receive the following error message when trying to run the installation command:
I’m not sure if this could be related, but I’m also having trouble setting up the Weather Integration. I’m getting the following error message here (copied from the log file):
Is there any tutorial how to install HA with USBImager? I can’t seem to get it… I’ve tried various ways, but I can’t seem to make any progress each time.
I’ve already tried these steps, but I am unable to go beyond step 9. I’m unable to execute the command “sudo usbimager”, I’m getting the error message “sudo: usbimager: command not found”. In the installation tutorial of USBimager it is written that I have to extract the zip file to “/usr”, however I don’t have permission to do that… So I’m stuck
Hi man,
did what everyone was saying in the comments…created one big EXT4 file system and ran the USB image with sudo…still i can’t select my SSD. Did you use additional commands to do so?
