I’ve been trying to install Home Assistant OS on the Pi5 for two days and keep getting an error. Here is an excerpt from the log:
24-02-15 22:30:38 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
24-02-15 22:39:00 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.2.1: 404 Client Error for http+docker://localhost/v1.43/images/ghcr.io/home-assistant/raspberrypi5-64-homeassistant:2024.2.1/json: Not Found (“No such image: Package raspberrypi5-64-homeassistant · GitHub”)
24-02-15 22:39:00 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
What’s going on here? Everything is at default with completely new as card :-(((
Yes, HAOS 11.5 running fine on Raspberry Pi 5. I originally used a microSD card, while waiting for my Geekworm NVME Hat to arrive. It is now running booting HAOS 11.5 off of a Samsung 970 EVO without any issues.
EDIT - found the issue. Had completely forgotten that I used an old 16GB SD card to do the install. Logs do not mention the update fails due to lack of disk space. Got a new 256GB card, update runs flawlessly.
