Hi all,
I am trying to make installation of ha-av working.
I am running with HA Core on Raspberry pi 3B v1.2 with os 11 (bullseye).
My version of HA is 2023.7.3.
When I run hass, I get the following error:
2023-08-25 18:27:45.330 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [80 lines of output]
Compiling av/_core.pyx because it changed.
[1/1] Cythonizing av/_core.pyx
Compiling av/error.pyx because it changed.
[1/1] Cythonizing av/error.pyx
Compiling av/plane.pyx because it changed.
[1/1] Cythonizing av/plane.pyx
Compiling av/format.pyx because it changed.
[1/1] Cythonizing av/format.pyx
Compiling av/enum.pyx because it changed.
[1/1] Cythonizing av/enum.pyx
Compiling av/bytesource.pyx because it changed.
[1/1] Cythonizing av/bytesource.pyx
Compiling av/stream.pyx because it changed.
[1/1] Cythonizing av/stream.pyx
Compiling av/packet.pyx because it changed.
[1/1] Cythonizing av/packet.pyx
Compiling av/frame.pyx because it changed.
[1/1] Cythonizing av/frame.pyx
Compiling av/option.pyx because it changed.
[1/1] Cythonizing av/option.pyx
Compiling av/buffer.pyx because it changed.
[1/1] Cythonizing av/buffer.pyx
Compiling av/utils.pyx because it changed.
[1/1] Cythonizing av/utils.pyx
Compiling av/descriptor.pyx because it changed.
[1/1] Cythonizing av/descriptor.pyx
Error compiling Cython file:
cdef const char *log_context_name(void *ptr) nogil:
cdef log_context *obj = <log_context*>ptr
return obj.name
cdef lib.AVClass log_class
log_class.item_name = log_context_name
av/logging.pyx:216:22: Cannot assign type 'const char *(void *) except? NULL nogil' to 'const char *(*)(void *) noexcept nogil'. Exception values are incompatible. Suggest adding 'noexcept' to type 'const char *(void *) except? NULL nogil'.
# Start the magic!
# We allow the user to fully disable the logging system as it will not play
# nicely with subinterpreters due to FFmpeg-created threads.
if os.environ.get('PYAV_LOGGING') != 'off':
lib.av_log_set_callback(log_callback)
av/logging.pyx:351:28: Cannot assign type 'void (void *, int, const char *, va_list) except * nogil' to 'av_log_callback'. Exception values are incompatible. Suggest adding 'noexcept' to type 'void (void *, int, const char *, va_list) except * nogil'.
Compiling av/logging.pyx because it changed.
[1/1] Cythonizing av/logging.pyx
File "/srv/homeassistant/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/srv/homeassistant/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/srv/homeassistant/lib/python3.11/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 118, in get_requires_for_build_wheel
return hook(config_settings)
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
self.run_setup()
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 507, in run_setup
super(_BuildMetaLegacyBackend, self).run_setup(setup_script=setup_script)
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 341, in run_setup
exec(code, locals())
File "<string>", line 157, in <module>
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1134, in cythonize
cythonize_one(*args)
File "/tmp/pip-build-env-g3sxpfn8/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1301, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: av/logging.pyx
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
│ exit code: 1
╰─> See above for output.
2023-08-25 18:29:18.089 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
│ exit code: 1
return obj.name
# Start the magic!
main()
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
self.run_setup()
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 507, in run_setup
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 341, in run_setup
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1134, in cythonize
File "/tmp/pip-build-env-52zn1fji/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1301, in cythonize_one
[end of output]
│ exit code: 1
2023-08-25 18:30:48.831 ERROR (SyncWorker_7) [homeassistant.util.package] Unable to install package ha-av==10.1.0: error: subprocess-exited-with-error
│ exit code: 1
return obj.name
# Start the magic!
main()
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 355, in get_requires_for_build_wheel
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 325, in _get_build_requires
self.run_setup()
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 507, in run_setup
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/setuptools/build_meta.py", line 341, in run_setup
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1134, in cythonize
File "/tmp/pip-build-env-ankmfxtl/overlay/lib/python3.11/site-packages/Cython/Build/Dependencies.py", line 1301, in cythonize_one
[end of output]
│ exit code: 1
I tried to follow the thread https://community.home-assistant.io/t/error-ha-av-with-2023-04/558497/7 by manually install ffmpeg release 6.0 or 4.4 but it doesn’t change anything.
I also tried to install ha-av with the following command “pip3 install ha-av”. The installation works properly but the error message is still present when I run hass.
Does anyone can help me please?
Thanks a lot for your help.
